2000 camaro ls1 t56 Weird noise under load
I have a 2000 Z28 m6. It's a heads/cam car (patriot 243's, comp 224 cam). Made 389 on a conservative tune. I'm getting this weird "rattle" like noise when I'm under load around 3-3500k rpm's. I've noticed it in 2nd, 3rd, and 4th. It does not make this noise if I rev it in neutral or if I push the clutch in. It's a really weird/hard noise to explain. Like I said only does it under load. And it's pretty load, I can hear it echo off walls/cars on the highway. And help as to what this could be would be appreciated, thanks.
Really need a video of the noise. Does it get worse when you turn? I am having a similar issue to you and I think I have it narrowed down to the power steering pump. Mine sounds very much like an idler pulley when it starts going bad.
It's hard to get a video. Only think you can hear in video is all exhaust at 3k rpm's accelerating. Haha
