Drilling 243 head pushrod holes
Old Mar 31, 2016 | 09:28 PM
RIPVTEC's Avatar
Default Drilling 243 head pushrod holes
Hello ls1tech,
I have been doing some reading and looking around.
Members are suggesting I run a 11/32 push rod. This apears to be in the $200 price range.
I do in fact have the 243 heads off the car as I have an extra set that were at the machine shop getting a valve job, milled, and springs put on.
Some say 3/8 pushrod clear some say they rub.
It sounds like it would be easy enough to enlarge the hole a tad to be able to clear a 3/8 with ease.
A 3/8 is much more price friendly at $100.
So my question is, is it okay/safe to just enlarge the push rod holes with a 1/2" drill bit.?
Is 1/2 in fact the correct size ?
Thanks again
Old Apr 1, 2016 | 01:24 PM
Boyes50's Avatar
Hi RIPVTEC. I would recommend getting in contact with Al @ Manton Pushrods. Al recently explained to me the pushrod selection decisions and guided me towards the 11/32" Series 5 Pushrods for my specific application. You can get a set of Series 3 11/32" Pushrods just below $200.00, and with the heavier walled 11/32" they will provide similar rigidity and better valvetrain harmonics then a cheaper, thinner walled 3/8" pushrod.
You would likely enjoy a reading of this thread from Corvette Forums. An excellent break down and explanation of pushrod size and requirements.
http://www.corvetteforum.com/forums/...stiffness.html
I considered drilling or opening my heads for larger pushrods but ultimately decided against it as I already had the heads mounted and torqued to the motor
Old Apr 1, 2016 | 04:53 PM
reaper68's Avatar
You can also run tapered 3/8's from trend as an option they work fine in my 799 castings
Old Apr 1, 2016 | 05:48 PM
dailydriver's Avatar
Jegs also told me that Comp cams has a custom pushrod built program (albeit with a 2 week lead time) that will do 11/32nds for ~$150.00.
Now, whether or not they are nearly as strong/rigid as the Manton/Trend 11/32nds mentioned above, who knows.
Old Apr 1, 2016 | 10:58 PM
BlackDuk98's Avatar
Go for the 11/32 Manton series 5, that is what I am also running. Max lift on my setup is .629. They clear fine with stock 799/243 pushrod holes. When I was changing my rocker bolt holds to m10s', I also drilled out the pushrod holes out with a tapered reamer and they are now 9/16, tons of clearance.
The 5/16 pushrods are .080 wall and the series 5 mantons are .120.
Old Apr 2, 2016 | 03:20 AM
DietCoke's Avatar
You don't want tons of clearance, you want .005 or so, because the head is going to expand a little bit. The head supports the pushrod in the same manner as a guideplate. 1/2" drill is the correct size.
Old Apr 2, 2016 | 07:08 AM
vettenuts's Avatar
Trend makes the pushrods for Comp, they don't make their own including the 5/16".
Old Apr 2, 2016 | 02:26 PM
RIPVTEC's Avatar
1/2" it is, thanks!
Old Apr 2, 2016 | 05:26 PM
BlackDuk98's Avatar
I have heard multiple ideas on this subject. I have heard of having the clearance like I have, I've heard that you can have them actually slightly rub and work like a guideplate - but they need to be checked with a sharpie marker and barely rub the marker off. I have seen 1/2"-9/16" used for clearancing.
On stock 243 heads with 5/16 pushrods, you have way more than .005 clearance
Old Apr 2, 2016 | 05:29 PM
Will they also clear the stock, un-drilled 241 head (and even earlier 2000 M.Y. f body heads') pushrod holes??
Old Apr 4, 2016 | 01:13 PM
Boyes50's Avatar
Al @ Manton advised me that 11/32" Pushrods will clear all factory LSx Cylinder Heads. Call them and have a chat with Al, he was beyond helpful with my build
Old Apr 4, 2016 | 10:37 PM
RIPVTEC's Avatar
Again I'd like to save the extra $100.
4 mins with a drill to fit 3/8 is no biggy
Old Apr 4, 2016 | 11:25 PM
DavidBoren's Avatar
That $100 is not worth saving... Don't skimp on your valvetrain...
Old Apr 4, 2016 | 11:31 PM
blk00ss's Avatar
Be careful not to go through the intake ports lol.
Old Apr 9, 2016 | 11:57 AM
RIPVTEC's Avatar
It's not skimping.
It's going to bigger od push rod.
Old Apr 15, 2016 | 05:57 PM
always faster's Avatar
Go read the VETTENUTS thread.The ID of the pushrod will make little difference in stiffness, the OD is the major controller.
Since my head was on the car i chose to run some Manton 5 series double tapered 3/8 .120'' wall pushrods.
If you got the head out of the car, just drill them and be happy to run better/bigger pushrods
