New engine ideas
Have thought about the 427 LS3 blueprint crate motor. then putting some extra into it.
Any other ideas or advice would be appreciated and welcomed.
looking for high hp and possibly boost, supercharger or turbo or procharger. or a good na build, open slate here.
you won't be disappointed, I wasn't anyway.
you need to talk to a professional builder, get a plan together and stick with it. And if you go that route I think you would be safe with starting with about double what you have now.
But that depends on your resources, capabilities, and so much more.
And remember you just can not pull a 350hp engine out and stick a 800hp engine in, and
start it up and go cruising you need to think about the rest of the vehicle.
clutch or converter, will your trans hold up, will your fuel delivery feed it? How bad has the
rear end been abused, how are you going to plant all of the new power to the ground?
Just saying lots of things to think about, tons more than I have listed I'm sure.
Anyway make a build thread when you start and take plenty of pictures, we all like pictures. Good luck
