5.3 lifter valve train noise??
Oh if it matters. Cam is 228 236 @ 50, .595 .612
Also have the trunion upgrade as well.
Starting on post #13.
The thread pitch on the rocker bolt is 1.25mm or .048", but the ratio is 1.7:1, so the pushrod moves 2.7/1.7 further than the bolt. .048 x 2.7 / 1.7 = .076". I use .075" per bolt rotation for easy math.
[rant]
There is a huge misconception out there that 1 rotation on the rocker bolt is .050. That's for the pushrod checker, NOT THE ROCKER BOLT.
Also, don't count rotations to 22-ft-lbs of torque. When you are torqueing the bolt, you are no longer adding preload - you are actually stretching the bolt.
[/rant]
It's all in the thread that Brew posted. Find dead-soft touch with the rocker bolt - and i mean just barely touching. Then, mark the bolt at 12:00, and use something to turn the bolt by hand, but only until it bottoms out. Don't torque it. Now, look at the clock position. 10:00 is close to .060" preload. Then, if preload is correct, put your torque wrench on and go to 22 ft-lbs.
The thread has pics, etc, which make it pretty easy to follow
[rant]
[/rant]
