Cam thoughts/recommendation
Old Jul 26, 2016 | 07:56 AM
Dragger56's Avatar
Default Cam thoughts/recommendation
I just got the trick flow top end kit with the 220 as cast heads for my 01 ls1. I wanted something more serious than the I believe .575 cam that usually comes in the kit. Iopted in for their .625/.625 278/286 advertised duration 113 lsa.
Has anyone ever used this cam? I was looking into the MS4 or Vindicator cam prior, would I be better going with something like that?
Thanks
Old Jul 26, 2016 | 08:01 AM
HCI2000SS's Avatar
What's the rest of of your mods, trans, gearing, etc?
Old Jul 26, 2016 | 08:16 AM
Dragger56's Avatar
Thenks for the reply.
Ls6 intake. Stock bottom end. T56 trans. Gears are undecided as of now but will be 4.11-4.56 on a 29.5" rear tire.
Old Jul 26, 2016 | 08:23 AM
HCI2000SS's Avatar
With your gearing you could get away with a bigger cam like the MS4, although some of that would be offset by the 29" tire. If it's just a street car you might like a cam like the 278/286 you listed much better
Old Jul 26, 2016 | 09:44 AM
finewayne's Avatar
.575 cam would be the perfect cam for just about any HD short of full race and the price is good too
Old Jul 27, 2016 | 11:48 AM
brobinson216's Avatar
Those heads do not require that much split. Choosing the right camshaft depends on which version of the 220's you have either LS1/LS2.
Call BTR and ask for his advice.
Old Jul 27, 2016 | 01:10 PM
Tuskyz28's Avatar
Just because a cam got more lift doesn't means it's go make a big horsepower number. Duration is more important than lift.....
Old Jul 27, 2016 | 02:09 PM
Darth_V8r's Avatar
Moderator
and yet... For some reason.... People post lift specs but no duration specs.......and ask how they'll run.
Old Jul 27, 2016 | 02:11 PM
Budget Deficit's Avatar
Hmmm Tooley loves to pair those heads with his Stage 4 cam which has a pretty decent split.
