396 Stroker - Burning Oil & Extreme Crankcase Pressure
I'm betting on rings. Probably weren't gapped correctly and bound up when the motor heated up. This causes the ring lands to break. You may not see anything in the oil because the rings are holding the pieces in place. The oil consumption fits this and the broken lands will cause compression to blow by and give the high crankcase pressure. I had this happen to a motor when I bought pre-gapped rings. Same symptoms as you have, seems like it had no top end power too.
Moderator
When he talks about the "gauge point" in the piston, he is correct that you can pull it down below the bottom of the cylinder at BDC, but that is with a incorrectly designed piston. He says the gauge point is about .500" below the oil rails, but in modern designs, it's more like .375". With those type of skirts, the gauge point stays in the bore with the longer strokes.
