L33 Loud at Idle (Normal?)
Hello,
I recently swapped out the LM7 in my suburban with a Junk Yard L33.
The L33 has 129,000 miles. I replaced all the gaskets and seals and cleaned the engine out as best I could when I had the valve covers, oil pan and front/rear cover off. There was a fair bit of crap in the oil pan but not too horrible. I have also cleaned out the lifters with B12 Chem-tool and performed a motor flush.
My question to other L33 owners is how noisy are these motors at idle?
This L33 runs great but I notice internal engine noise that I never had with my LM7.
It does not knock or make any really bad noises, but I notice valve train or lifters or something is louder at Idle than my old LM7. I also replaced the oil pump and pickup o-ring with new ones and have good steady 50-60PSI oil pressure.
Other L33 owners please chime in and let me know if you notice hearing the engine internals at idle on your L33.
Thanks
Thanks
Original lifters though I assume? All things created equal and in good running order I wouldn't expect the L33 to have any more noticeable noise while running than the original LM7.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Yes Original Lifters.
I just thought maybe I was hearing more due to an Aluminum vs cast iron block?
Also I replaced the exhaust Y pipe while replacing the motor. The old Y-pipe had pre-cats directly after the flange where they bolt to the manifolds and the new pipe does not. My exhaust is slightly louder but not much. And it is not an exhaust noise I am hearing definitely internal engine noise.
Thoughts?
Thoughts?
The difference in noise is not something in my opinion that you would notice. I would pull a valve cover make sure a rocker hasn't backed off, and if everything looks good there you might want to take a closer look at the lifter situation.
__________________
Could I be hearing the lifters?
I thought they would be more of a loud tapping sound?
This is more just like a crunching type sound at idle?
I guess it could be lifter noise?
I don't want to have to pull the heads to replace them though. I will just send the engine back and get another under warranty. Any ideas on how to determine what the source of the noise is?
I have pulled all the rockers and blasted each lifter with B12 and looked down at each one with a lite, they looked fairly clean?
I re torqued all the rockers back on to spec. and performed a motor flush.
Same noise still there, at idle only, when I rev it up it sounds smooth and I don't here it?
Are you sure it is an internal engine noise?
__________________
L33 idle
Thanks
Thanks
hope this helped best of luk
Hello,
Thanks
Thanks
