Bearing clearance problem LQ4
What's the full part number for the bearings?
I use shops that acid dip which removes ALL porosity from the coolant passages
Many shops still "bake and tumble" and I've seen way too many instances where a crank that came out if an engine won't turn or turns too tight after the shot tumbling process tightened up the main bores. Thus crushing the bearing shells too tightly. These blocks need a kissing from a line hone for the mains to be correct spec again
The Plastigauge is not as accurate as a mic and dial bore gauge with .0001" increments, but it's better than nothing. Usually the standard bearings are a little tight, but it shouldn't be an interference fit. You may have to swap the MB5013XP bearings out for a set of MB5013XPSTDX bearings to get your clearance where you want.
Main Journals mic out at 2.559. Bearings torqued down mic out at 2.560. Which is pretty close to the reading I was getting with the plastigauge of .001. I also just mic'd the rods and bearing. Crank journal was 2.100, rod opening was 2.223. The bearing width was .068. So that tells me they'll be too tight as well. If I did that correct. Rod bearings are King CR807HPN. Thanks for all the advice.
King specs. 2.7509/2.7514. 2.5588/2.5593. .192. .0001/.0006
Main cap/ Housing diameter/Crank diameter/Bearing clearance/Total Clearence
1. 2.7475/ 2.5588/ .192/ -.0033
2. 2.7460/ 2.5588/ .192/ -.0048
3. 2.749/ 2.5588/ .192/ -.0018
4. 2.7505/ 2.5588/ .192/ -.0003
5. 2.749/ 2.5588/ .192/ -.0018
Looks like the main caps are too tight and probably need to be line honed. I do have a question though. On Kings website, if the crank and mains fall within the peramiters they set. The clearance ranges from .0001-.0006, which still seems very tight. Am I calculating this incorrectly?
