Oil poured out of that oil-related fitting above filter when removed. Normal?
You know where you connect your oil psi and oil temp sensors just above the oil filter? That. Is it normal for oil to pour out from there (about 200ml) when you remove it while the engine is off and cold-ish?
I have no engine dipstick so I'm paranoid I had/have too much oil in the sump.
Yeah 200ml is about a small cup. I think the average Coke can in the US is 355ml, so if you drank about 44% of it, you'd have around 200ml left.
No pic is needed. There is only one place where you usually connect your oil temp and/or oil psi sensors/fittings to, right above the oil filter area on the top rear left-hand side corner area of the oil sump/pan. It has 2 small nuts holding it in place and is about 2 inches wide and 1 inch tall.
talking about is the oil cooler block off plate, it just happens to be convenient
place to put a pressure sensor there.
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_1772_f0ef3022bf51c4f1006700a59b7ff8c3f7f6ab6f.jpg)
Nope. There's only 1 oil-related thingo directly above the oil filter where you attach your oil-related fittings to. It couldn't be easier to understand or think of.
Actually, does that involve welding a fitting to the sump? Pff, forget it.
Last edited by ChevFTW; 10-17-2016 at 01:03 AM. Reason: I felt like it. Anything else you wanna know?
