Windage Tray: necessary?
Old Apr 5, 2018 | 08:18 PM
DietCoke's Avatar
Your engine will run fine with a rod/piston/injector not installed on any one cylinder.
You can also drive a car with your feet if you wan to.
Doesn't make it a good idea.
Old Apr 5, 2018 | 08:39 PM
BOOM! Fred Flintstone thought his ride was cool, too. Do we???
Old Apr 6, 2018 | 05:46 PM
joecar's Avatar
Originally Posted by Pantera EFI
He supplied an "A" engine AND requested a VERY DEEP "windowed" Oil Pan be installed allowing a "view" of the internal oil windage with a running engine.
A lot was learned with ANOTHER MYTH proved incorrect.
The engine oil is NOT "thrown" into the Oil Pan, in fact the opposite occurs.
The oil remains attached to the crankshaft, rods, rotating items such as you find in a Tornado.
I called the effect a Salt Water Taffy.
Direct observation
Old Apr 6, 2018 | 08:38 PM
Originally Posted by joecar
Direct observation
From one who KNOWS, because he has BEEN THERE, and DONE THAT....
Old Apr 6, 2018 | 09:19 PM
Would still love to see testing on this. Maybe Improved Racing has done testing on the LS platform, tray vs. no tray?
As I said previously, my super high end circle track sbc’s made more power without the trays. Dyno proven results, but a different engine platform.
Old Apr 7, 2018 | 01:53 PM
ImprovedRacing's Avatar
LS1Tech Sponsor
We've never done a test with no windage tray at all. It would be interesting to see what happens but might be a little risky if it results in foamy oil, causing oil starvation and engine damage. Not sure if we want to blow up an engine just to find out.
It's definitely a good idea to run a windage tray. Why not?
A crank scraper is even more effective at removing oil from the rotating assembly. In some cases we run a crank scraper and no windage tray. In the C5 batwing pan, for example, we run a scraper but our windage tray won't clear the pan. Because the pan is so shallow and close to the rotating assembly already, with a crank scraper in place you don't really need a tray as the covered upper section of the oil pan basically acts as a windage tray.
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Old Apr 8, 2018 | 11:27 AM
pantera_efi's Avatar
Default Water Thunder Oil Pan Tech
Hi ALL, my customer Dave Hartz, Water Thunder, assembles over 400 LS engine in a years time.
We shared some Oil Pan Tech when I designed my LS Oil Pan.
He stated that he was able to report "tech" about an engine test with NO OIL PAN FITTED.
This engine was benched AND a 1/2 cut open 55 gal fuel drum was placed under the operating engine.
The Back/Back dyno reported a HP increase when NO Pan was fitted.
Call Dave for the full report or Engines.
Lance
Attached Thumbnails Windage Tray: necessary?-dsc_0347.jpg   Windage Tray: necessary?-dsc_0348.jpg   Windage Tray: necessary?-dsc_0349.jpg
Old Apr 8, 2018 | 07:48 PM
DietCoke's Avatar
Lance
Well sure, the engine isnt working against pressure/windage with no pan in place. What a pointless metric
Old Apr 8, 2018 | 08:22 PM
Don't be so freakin' IGNORANT! It shows what happens when what's below the crank is not a factor, and it IS GOOD TO KNOW! Lance has more experience/knowledge in his left pinky than you ever will.
Old Apr 8, 2018 | 10:29 PM
DietCoke's Avatar
You're right. When I need an extra car length in a race I'll just unbolt my oil pan and open my accusump. That should get me there.
Old Apr 8, 2018 | 10:43 PM
As usual, you missed the point.... you only see things as they relate to YOU. Well guess what, to quote Dr. Phil, "It ain't about YOU!"
Old Apr 8, 2018 | 11:20 PM
  #32
bammax's Avatar
I think you're focusing on the speaker instead of the message. It's not rocket science to figure out that the crank hitting the oil in the pan will cause resistance. If the topic was about running a deep pan or less oil then it would be more relevant. On a topic about windage trays it's really not a great anecdote.
Old Apr 9, 2018 | 12:02 AM
  #33
True. I got a little riled.
It's not so much about the crank HITTING the oil, but more about WHIPPING up the oil below the crank, hence the need for windage trays.
Old Apr 9, 2018 | 12:05 AM
  #34
DietCoke's Avatar
Too busy white knighting your california friend.
Old Apr 9, 2018 | 10:35 AM
  #35
Speak for yourself. I respect knowledge more than over-opinionated bigmouths like yourself. I've never met the man. Sounds like you meet them in a biblical way yourself....
Old Apr 9, 2018 | 11:26 AM
  #36
bammax's Avatar
Very true. Churning the oil is never a good thing. That said, a windage tray that sits too close to the crank can actually hold a puddle right in the path of the oil whips coming from the crank which can add friction. That's why a crank scraper is so handy
Old Apr 9, 2018 | 12:18 PM
  #37
Default Professional Motorsports "tech"
HI ALL, thanks for the kind remarks.
SURE, I baited/hooked MANY here with the "panless" engine report, a TRUE REPORT !
This test was a REQUIRED test to PROVE to Dick Moroso that HIS Oil Pan/Scraper design was NOT PERFECT.
MANY here will spend 3K dollars on heads/cams/etc. for 20 EXTRA HP, then NO Money on a good windage/scraper tray that would cost LESS THAN $100.00 providing the SAME increase in HP.
Lance
Old Apr 9, 2018 | 02:23 PM
  #38
bammax's Avatar
Lance
That's a big thing for people to keep in mind. Companies spend thousands advertising in magazines and on tv/internet convincing people that they need high end race parts on their grocery getter. Half the time these companies aren't even doing a good job making the parts they advertise. People then don't have the money left to get the parts they actually need.
Windage trays are like other performance parts, for some situations it's a must and for others it's unnecessary. It's up to the builder to figure out exactly what's needed based on how the engine is going to be used. The recommendations for a scca road track vette aren't the same recommendations as for a suburban that only drives 5 miles a week to the fishing hole.
Old Apr 9, 2018 | 05:05 PM
  #39
Lotsa truth here! I think GM put windage trays in the LS engines NOT because it is necessary in all cases, but to cover themselves IF the extreme circumstances should happen on ANY of there engines. Good thinking if you ask me...
Old Apr 9, 2018 | 09:17 PM
  #40
Default Gm cafe taxes
Hi GARY, SURE GM would SAVE MILLIONS when they REDUCE CAFE taxes, TAXES ABOUT FUEL consumption !
THUS, great savings for GM in Emission TAXES
THUS THOSE "bean" counter's RULE, thanks AGAIN.
Lance
