advice on heads
Old Dec 19, 2016 | 06:00 PM
Darth_V8r's Avatar
Moderator
Originally Posted by ssliver98
And sorry to keep bugging u but is the 430 gear a hindrance to a build with with mms heads and smaller cam
That's a good question, honestly. higher gears will dyno lower, but move th car faster. Odd experience, but When I first put the 4.11 gears on my car, from 3.42, I was honestly unimpressed. Sort of pissed actually. I took vids and sent to some friends, and they said to go look at my old vids - car was faster for sure. But then, I put 28" tires in, and the car moved ALOT faster. That's like saying the car was faster on 3.90 than it was on 4.11.
So, short answer, but for a street car, I'd go with the 3.90 or 4.11 gears. If you already have the 4.30 gears in, I'd leave them. if you are running a short *** tire, then get lighter wheels and taller tires instead of regearing.
Old Dec 19, 2016 | 06:04 PM
ssliver98's Avatar
The car had 4:10s and I wasn't impressed.when I had the mwc fab 9 built I went with the 4:30 gear and car is a whole lot better.but that could be to the new torque arm lcas,and strange shocks because wheel hop has been totally eliminated. And car feels all around faster no slop in take off
Old Dec 19, 2016 | 06:10 PM
Darth_V8r's Avatar
Moderator
Then I'd leave it as is and just build the top end. Again, if you decided you wanted less gear, just go with taller tires - unless you're already 28"
Old Dec 19, 2016 | 06:13 PM
ssliver98's Avatar
Thanks for you're help. I think I'm gonna go with the sportsman heads. Now I just have to decide on cam
Old Dec 19, 2016 | 10:28 PM
DavidBoren's Avatar
If you are getting the heads from Tony, you can probably ask him what cam he suggests for his heads.
Old Dec 21, 2016 | 06:24 PM
TT427's Avatar
Just something to think about, the. BBK is basically like an LS6 intake... it's really going to be the limiting factor in flow. If you plan on going wilder in the future with intake mods and a big cam etc then a bigger head is fine but you might want to consider a smaller runner if not going that route. Just about any ported factory casting and aftermarket casting will outflow the intake. I would look at any 205-215 aftermarket casting in this instance, of course Tony or Brian or whoever you choose will point you in the right direction with your goals now and later. Consider too you likely have 806 perimeter bolt heads so covers and coil brackets become an expense among other unique things.
Old Dec 21, 2016 | 06:30 PM
Darth_V8r's Avatar
Moderator
I'm no fan of the BBK by any stretch, but mainly for weight and heatsoak. The BBK is a very short runner intake with a 85mm mouth. It might be a phenomenal boost intake- again except for the heat soak because aluminum.
Old Dec 21, 2016 | 06:41 PM
ssliver98's Avatar
The previous owner wanted to boost the car
Old Dec 21, 2016 | 06:42 PM
ssliver98's Avatar
I still plan on the heads and cam. Later on I can do intake,I'm not really going max effort
Old Dec 22, 2016 | 07:57 AM
gagliano7's Avatar
So the mamo heads are around 2100? Prc 1700 so how much is left on the table for four hundred less
Not trying to sway you either way but with the Mamo heads you will have to use yella terra rockers which will add to the price.
Old Dec 22, 2016 | 08:00 AM
Rise of the Phoenix's Avatar
OP, if you haven't already, checkout the Advanced Induction Dart/RHS 223cc heads. Fully CNC'd aftermarket castings and are at a very reasonable price. I have them and they made 447 rwhp and 431 rwtq, and that's with a bone stock LS6 intake and unported TB.
Old Dec 22, 2016 | 08:19 AM
  #32
mjs1012's Avatar
IIRC AI doesn't do the dart heads anymore according to Phil last time I spoke with him. It's been a while so maybe things have changed.
Old Dec 22, 2016 | 12:35 PM
  #33
I purchased my set several years ago and actually got them at a price lower than what was advertised. It's a shame if they aren't because they are very high quality heads that make great power.
Old Dec 22, 2016 | 12:43 PM
  #34
Darth_V8r's Avatar
Moderator
I thought that was only true with the AFR castings - like his 220's and 235's.
His sportsman heads are worked over trickflow castings. Pedastals should be the same as a trickflow 220.
Old Dec 22, 2016 | 01:18 PM
  #35
mjs1012's Avatar
For the price they were, and after looking at your build I asked him about them for my car and he told me they stopped selling them. This was a year and a half ago.
OP if you're ready to pull the trigger on heads right now there's a set of TFS 215 w/ rockers and AFR 210 classified section.
Old Dec 22, 2016 | 01:20 PM
  #36
JakeFusion's Avatar
Super Hulk Smash
So they are his hand finished TFS 220s? Interesting.
I know his work on the TFS LS3s and LS7s have taken them to the next level.
I wonder what Tony could do with a set of TFS 245s...
Old Dec 22, 2016 | 01:29 PM
  #37
Could be an issue with getting the castings. I believe RHS bought out the Dart castings, as my heads are stamped with the RHS logo.
Old Dec 22, 2016 | 01:35 PM
  #38
Darth_V8r's Avatar
Moderator
I'm not sure if they are hand-worked TFS-220 or if he has contracted with them for a custom casting based off the TFS-220. I just know that they are based on that casting.
Tony won't attach his name to something that runs poorly, though, so either way it's bound to be a great head. I'm sure he could do quite alot with a TFS245.
Old Dec 23, 2016 | 07:42 AM
  #39
gagliano7's Avatar
In this thread https://ls1tech.com/forums/generatio...man-heads.html Tony says he uses bronze guides which you should use roller rockers like he recommended. He said you could use stock rockers but he doesn't recommend that.
Old Dec 23, 2016 | 07:57 AM
  #40
ssliver98's Avatar
The heads that are on the car now have roller rockers
in them was just gonna reuse those.....
