Ls1 build advise
Bought a set of 243 heads off an ls4 and a gmpp cam (late ls6) and gmpp blue behive springs. I am hoping a hone job to clean up the block and I don't have to replace the pistons. Any advise would be helpful
99 LS1 block, crank, pistons, rods with K tech rod bolts.
The piston had a broken ring land, and left a very slight marks on the number two cylinder wall. I have a replacement piston. I also have an LS1 intake with fuel rails, injectors and a throttle body.
I also have an LS2 intake fuel rails injectors (32lb), and a three bolt throttle adapter. Also have ls6 intake, and a set of LS four injectors (28lb)
LS6 intake out flows the LS2.
Throw away the stock pistons and get a quality forged replacement set. Ideally, Wiseco or Mahle are my favorites.
You can get a better cam as well.
Take the block to D&D Parts and Engine and have them look at it.
6634 Vine St, Cincinnati, OH 45216
What are your goals with the car, overall?
The stock LS6 piston is better quality than the LS1 piston because its made with a stronger alloy. It might be possible to find an inexpensive set and use them. Probe also makes a forged LS1 piston that looks pretty decent for around $500 per set. Pistons are not one of the areas to cut corners in my experience - if they fail they often take other stuff out and it gets expensive. Someone else maybe able to help with piston suggestion. I'm of the mind that all three of my engine builds could sit and wait until I had saved enough for Wiseco or Mahle. I'd rather pay $300 more for quaility, do the task once, do it right & not worry. Different folks have different opinions on the issue and approaches.
The 28.8 pound injectors can support 450 wheel hp maybe a little more if they are in excellent condition and the rest of the fuel system is in excellent condition. There isnt much safety margin as the injects will be maxed out or nearly so. My 99 TA has 26# injectors and makes 418 rwhp.
Since you have #32's I would use those. The LS2 injector is a shorter than the LS1 injector. There should be an spacer/adapter to make it work in the LS6 intake.
I'm not familiar with Cincinnati, so can't comment on the machine shops.
I wish you the best with the build.
BTW - a good job porting job the stock TB will pick up a few hp for cheap.
28# injectors will be pretty much maxed out at 450 whp. I plan on replacing mine soon, along with my fuel pump as I have maxed out my stock system. However, with 243 heads and a small cam and a little 346, like the one you mentioned, you won't be near 450 rwhp.
