Ported LS6 Heads vs. LS1 Heads?
I ask because, well, I have an option to pick up a set of lightly-used '03 LS6 heads (complete, ready to bolt-on), and I am contemplating using these for cores and getting a ported LS6 set. Or, the other more economical option would be to just purchase ported LS1 heads, use my LS1 stockers as cores, and completely forget about using the LS6 heads (stock and/or ported).
With that said, here's my mods & what I use my car for... '02 Firehawk, M6, stock LS6 intake, '02 LS6 Cam, StainlessWorks longtube headers w/ RT high-flow cats, P/P TB, ASP pulley, custom PCM tuned, and a few other minor bolt-ons (stock MAF). Stock 346ci displacement, and it'll stay that way. No turbo/SC are in the long-term plans.
I *rarely* go to the 1/4-mile track (never gone yet with the Hawk). I want a fully street-friendly setup, no "quirks", as I am building the car for (street) power. With the addition of the heads, I can also forsee another cam-swap to one that is a bit bigger but still friendly for stockish-idle quality & behavior. I will gladly give up HP for better all-around driveability & behavior, as this car needs to both cruise nicely at 75mph and also sit for long-periods in 0-20mph stop-and-go rush hour traffic. Hence, a big lopey cam is completely out of the question. (Would then going with a extremely high-flowing head be a waste of $$?) I would like to raise the CR a bit, and prefer low/midrange torque over high-rpm HP.
What sort of flow and HP benefits does a S1/S2 LS6 head have over a S1/S2 LS1 head?
Any help is appreciated. The 'search' isn't turning up much helpful information; at least, not yet....
and if i were you id just go with TSP race style stage 2 5.3 heads... there a cnc head with hand polishing! get them with a 10.8:1 CR, dual springs, Ti retainers, Hardend pushrods, ARP bolts etc...
and if you want low end more than top end id say get a COMP 216/218 535? lift 114
they have great deals on H/C combos
With my small 222/224 cam I got 400rwhp. Go for the LS6 heads every time. It also gives you some room to move if you want more power (ie. stgII or stroker)
Using the LS6-cam (for now), I'm trying to figure out the bang vs buck 25hp @ $800 = $32/hp. Ported LS1 head ~40 hp (??) @ $1500 = $38/hp.
I totally appreciate the replies.....
Off topic question... If you are building a motor, don't you just get your compression through the pistons (well, most of it anyways)? So you want 11.1 compression, and you are building a motor, you would buy pistons that are made to get 11.1, not a regular stock style piston and them get the heads milled or whatever to get your desired compression?
I am not an expert on this, so I this is just what I have gathered from seeing engine's being put together, the correct way is through the piston, etc, not the head, correct?
- Dug
