Etp 215 heads And push rod Q?
Okay so i have ETP 215 heads and i was ball parking the push rods with my Comp 7702-1 checker and holly hell the push rods are long. Is there any one else running this head how long are your push rods. mine with the heads milled down to 58cc i am still at a 7.800 with alittle over a half a turn of preload in the lifter Moral lifters. just seeing what others have came up with on this head.
http://www.yellowbullet.com/forum/sh....php?t=2059026
This guy on the bullet is setting his up now, theres another guy in that thread thats has ran ETP heads also. I remember them being long when i was looking to get a set of those heads. I have some info saved somewhere but cant find it.
Not sure if this helps, seems like 8.1 is sort of a starting point with cam base circle, lifters, rocker stands and milling heads adding wild cards to lenght.
See post. #10
http://https://ls1tech.com/forums/generation-iii-internal-engine/532418-what-rockers-pushrod-combo-your-etp-heads.html
Also might help...
http://http://www.corvetteforum.com/forums/c5-tech/1343365-pushrod-length-for-etp-215-heads.html
See post. #10
Also might help...
8.1 seemed like the starting point depending on cam base circle, lifters, rocker pads and if the heads were milled adding variance...
Not sure if this helps, See post. #10
Also
http://www.corvetteforum.com/forums/...215-heads.html
Also
