Pushrod # check
You can't use a lifter to do this, you need a solid lifter and you must be at zero lash. Put on a set of check springs so you can use an adjustable pushrod to achieve zero lash. I think your lifter plunger was compressing giving the appearance of much greater PTV than you really have.
