New LS1 Hyd and Solid roller lifters. . .
Old Jun 24, 2004 | 11:28 AM
Cstraub's Avatar
Default New LS1 Hyd and Solid roller lifters. . .
I'll have samples of the lifters in a few days from Morel and will post some pictures of them. The solid will feature proprietory oiling directly to the roller for extended life. Both are fully machined from bar stock and centerless ground to an OD tolerance of +/- .0003".
Chris
Old Jun 24, 2004 | 11:38 AM
RyanJ's Avatar
SSU Moderator
what about solid rollers with very high lift (the oiling problem). Will these solve that issue?
Old Jun 24, 2004 | 11:44 AM
Cstraub's Avatar
Yes, these are not std chevy bodies modified, this lifter is engineered specifically for the LS1.
Chris
Old Jun 24, 2004 | 02:50 PM
Futral's Avatar
These lifters will be a VERY good option for a solid roller setup. and very nice looking pieces. The locating band of the lifter is raised up approx .132" vs the Crane drop in lifters. This is where you run into oil pressure issues with high lobe lift cams. They will be a little cheaper than the new Comp's and easier than making other types fit.
Old Jun 24, 2004 | 02:54 PM
gomer's Avatar
Chris
How much $$$ are we talking about for a set of the solid rollers?
Old Jun 24, 2004 | 03:38 PM
Cstraub's Avatar
I'll let Alan and the rest of the sponsors set those prices Gomer. As soon as I get the samples I will post some pics.
Chris
Old Jun 24, 2004 | 08:14 PM
Ed Curtis's Avatar
Talking
Chris
Non-sponsors will have them too....
BTW Chris... Ed M. still owes me a few "items"...
Ed
Old Jun 25, 2004 | 05:34 PM
GrannySShifting's Avatar
Tell me about these hydraulic lifters
Old Aug 17, 2004 | 06:09 PM
2001CamaroGuy's Avatar
any more info?
Old Aug 17, 2004 | 06:52 PM
TVWilkes's Avatar
Chris send me a sample.
Old Aug 17, 2004 | 10:25 PM
Cstraub's Avatar
I'll get a hold or Morel. I have been busy and not talked to them to get an update. I will find out tommorrow and post.
Chris
Old Aug 17, 2004 | 11:05 PM
racer7088's Avatar
Thumbs up
What is better about these lifters Chris? I haven't ever had any lifter problems really so far but I know the quality is supposed to be better on these I guess. It's always better to have more choice in anything. I knew these guys did some specialty lifters but not LS1 stuff.
Old Aug 17, 2004 | 11:07 PM
racer7088's Avatar
When you say both do you mean a hydraulic and solid roller model?
Old Aug 18, 2004 | 10:11 AM
Ed Curtis's Avatar
Talking
Erik,
The Gen-1 lifters are so sweet I didn't want to install them in an engine...
Like little jewels...
You'll like them, A LOT!
Ed
Old Aug 18, 2004 | 10:14 AM
Originally Posted by EDC
Erik,
Ed
INFO! PLEASE!
cost, part number, any mods to block to use them, etc.....
Old Aug 18, 2004 | 05:13 PM
Beast96Z's Avatar
Are they as picky to pre-load as the comp R's?
Old Aug 18, 2004 | 05:28 PM
Likely they wont have as much plunger travel either so they probbably wont want a ton of preload either. besides, preload slows you down whatcha want that for?
Old Aug 18, 2004 | 09:59 PM
Beast96Z's Avatar
It's not that I want it there, but setting up shims kinda sucks for those that don't want to go with adjustables. If you could use just one set shim and allow for the lifter to make up the variance, it would be much easier.
Old Aug 18, 2004 | 10:20 PM
mikey's Avatar
LS1TECH Sponsor
Chris, can you give me a call at your convenience? I'd like to talk to you about these as well as a few other items Number in sig.
Mikey
Old Aug 19, 2004 | 08:57 AM
racer7088's Avatar
Thumbs up
Erik,
Ed
I'm just glad more stuff is becoming available for these engines. We've not had any lifter trouble yet but I know Morel is a nice product.
