What is the max RPM for this setup?
Btr4 cam, btr springs and titanium retainers, btr pushrods, 1 3/4 headers, open x pipe, borla stingers, ls7 clutch, btr trunion upgrade
Or just take the advice of the guys building your car
All of them work to 7500 with a light enough valvetrain.
The FAST 92 isn't going to want to go that high... and neither is that cam. There's no reason to go past 7k with that combo.
The LS7's would work, but the 5315 lifters have a couple features that make them better, but you may not really see an advantage on the dyno. Same with the 2110's. They have features that make them better, but depending on the rest of the combo, you may not realize those advantages on the dyno.
Cathedral port heads and long runner intakes, like the FAST, aren't really known for developing power after about 6200-6500 RPM. If you're going to see any power from a different hyd. lifter, its going to be mostly at higher RPM where it would be more stable than a lesser hyd. lifter. With the engine combo you described so far, it doesn't really sound like they'll be worth the money IMO.
My point earlier was that the guys building your car should have a good idea of how these lifters will work considering the total package. Obviously "to the moon" isn't a real answer, so I would lean on the expertise of the guys with the more technical answers.
