MS4 Cam
Old Feb 10, 2017 | 02:35 AM
whatsa347's Avatar
It's about the combination, I ran a TSP 5.3 headed car with a 228 cam and got my *** absolutely handed to me, granted I was on stock heads and **** tires, but still my old LS6 with a 230/232 ran it's *** off and door to door wth some fast local Houston cars. I'm a firm believer of a smaller cam and good set of heads.
Old Feb 10, 2017 | 06:40 AM
codyvette's Avatar
If you want to give it a go, I just pulled an MS4 from a part out. $250 shipped.
Old Feb 10, 2017 | 08:27 AM
TXZ28LS1's Avatar
Anybody remember TRMIN8R's SS?? Just sayin...
Old Feb 10, 2017 | 08:29 AM
tug686spd's Avatar
How about a littke big cam inspiration. Ported 243's and big cams from 10 years ago running with the best of todays heads and cams.
https://www.google.com/url?sa=t&sour...MWvwqajcC309wA
http://redirect.viglink.com/?format=...QDK70Af8fvMwDg
Old Feb 10, 2017 | 10:46 AM
whatsa347's Avatar
No one is saying they don't work, they just need way more supporting mods with it, we all know the times the old T-Rex cam cars put up, but look at the mods they have with them like a 9 inch, 4.56 gears, slicks, flycuts, FAST and weight reduction. I'm pretty sure the MS4 still holds the stock bottom end record as well, so it does work, it's just if you're going to drive your car anywhere else besides a quarter of a mile at a time, there are other, better choices out there with a set of heads that can accomplish the same thing.
Old Feb 10, 2017 | 11:58 AM
tug686spd's Avatar
Now I'm confussed? So your saying a better intake, exhaust, rear end and sticky tires isn't recomended with smaller heads and cam package?
Clearly all that stuff is needed anytime you add power to just about any car. Pretty weak argument you presented there. And if you think the 410 or 456 gears give you a little bit of an argument there is plenty of people still getting well over 20mpg with them. On this very forum a 3600-4000 stall is usually recomended for a stock motor and thats all thats needed to make a big cam shine also.
Old Feb 10, 2017 | 12:13 PM
whatsa347's Avatar
Where did gas mileage come from? Why are you bringing up irrelevant things to a discussion about supporting mods for a max effort car? Someone clearly hasn't owned a max effort cam only track car.....go look at the cam only fast list, let me know what you find and see what's similar between all the setups
Old Feb 10, 2017 | 07:59 PM
07NBSChevy's Avatar
If you want a great streetable cam, the TSP Torquer V2 232/234 .600/.600 on 112 LSA is awesome. Even the 233/239 .600/.600 on a 112 LSA. The MS3 is on the verge for a streeable cam for a smaller displacement motor.
I have not been around the MS4, I personally have not been around cams over .600 lift for a street car, or really see the need for anything over .600 for relatively stock heads. Also, staying under .600 helps with valve train durability.
Old Feb 11, 2017 | 06:09 AM
VincesSS's Avatar
Originally Posted by kinglt-1
Some people are simply more tolerant of large cams then others and that is fine. I don't care how good the tune is, you can only do so much with a cam that has 20+ degrees of overlap. They are so inefficient around idle and have lots of reversion that there will always be some negative effects on how it drives. If you have the proper supporting mods they can be tolerable for a weekend street car but it's something I would ever recommend for somebody that wants a driver. I think most would agree with this.
This is so true. I'm running a btr stage 4 in a sbe ls1. Car idle is violent, runs great, even better on the 200 hit. I would drive this everyday if I didn't need a truck for work, but I'm sure most would disagree with dd'ing this cam.
Drivability is in the eye of the beholder.
Old Feb 11, 2017 | 10:31 AM
uraloser2me2's Avatar
Must be a world of difference between the ls1 stage 4 and the ls 3 stage 4 cam I have in my 5.3 or maybe it is the difference between carb and efi. I would not describe the idle as violent at all. Has a nice stable idle at 850. I don't daily the car, but it isn't because of the cam.
Old Feb 13, 2017 | 05:57 PM
tberg725's Avatar
I have never herd the term "max effort cam" before what do you guys mean when you say that? I ran a pretty big cam in my 408 windsor build so im tolerant of big cams and dont mind adding all the supporting mods as im not worried about spending the money when it comes to buying all the right things for my car
Old Feb 14, 2017 | 08:47 AM
  #32
thunderstruck507's Avatar
Max effort means it's among the cams designed to push the limits of a stock bottom end LS1.
It's basically as big as you can go before flycutting is required (and I've seen some instances where users with stock engines found places the valves had kissed pistons). The faster guys I've seen running them are turning 7000+ rpm even though the cam peaks earlier.
Combination of marketing to be the biggest and baddest available and also useful for those who were seeking stock bottom end records.
They work well for their purpose if you build the rest of the car to suit them.
Old Feb 14, 2017 | 10:31 AM
  #33
tberg725's Avatar
Well then it seems the max effort cam is what i am looking for the most i can get out of it if i go with the ms4 cam then i will buy the heads or have heads ported to suite it and from what it seems i will be best off running an ls6 intake untill i can afford the fast intake unless there is a better intake that would suite a big cam better
Old Feb 14, 2017 | 05:51 PM
  #34
kinglt-1's Avatar
Yes...a Mamo ported MSD would love a big cam. I would go Low Lash Solid before a big hydraulic...PM DarthV8 for details on his setup.
Old Feb 15, 2017 | 03:59 PM
  #35
tberg725's Avatar
Not quite sure what that is?
Old Feb 15, 2017 | 04:27 PM
  #36
2002BLKWS6's Avatar
Take a look at these two threads:
https://ls1tech.com/forums/generatio...orted-msd.html
https://ls1tech.com/forums/generatio...o-fast102.html
Some good info in both.
Old Feb 15, 2017 | 04:51 PM
  #37
tberg725's Avatar
Thanks for posting that, vary good reads, sense I do not really want to spin the bottom end past 6,500 it seems the fast intake would be better for me
Old Feb 16, 2017 | 08:43 AM
  #38
If you don't want to spin past 6500 you are back to the MS4 being the wrong cam for you as well.
Old Feb 16, 2017 | 09:06 AM
  #39
tberg725's Avatar
That was a mis type on my end I ment to say I dont want to spin the bottom end far past 6500 but on texas speed website they dont go over the rpm operating range but from the dyno runs I have seen of builds that have the ms4 in it the cam is making peak HP at 6,400rpm putting me in the rpm range I feel comfortable being in, what are the rpm limitations of the stock lower end
Old Feb 16, 2017 | 10:12 AM
  #40
Peak could be around 6400 but the fast cars using that cam tend be shifted at 7,000-7,200.
Limits? Who knows. Some fail stock and some live at 7,400.
My previous engine was a 1998 LS1 and I spun it to 6,800 every time I drove it. Still perfect when pulled to swap for the LS2.
