Custom cam vs Shelf cam
This is what Brian Tooley had to say on FB about the topic.
"I would like to talk about CUSTOM cams vs "SHELF" cams. Every cam we have on the shelf IS a custom cam, and they performed well enough that we decided to stock them on the shelf.
We just had a customer in a 3000lb street car run 4.50's @ 162 in the 1/8mi with a hydraulic roller cam, which is the fastest LSx at this weight running a hydraulic roller cam. Just so happens that this cam is on the shelf because it has ran 159 and 160 in two other combinations.
Some applications are unique enough to require a custom cam, most are not.
So here is how you should think about cams:
SHELF cam = Proven cam.
CUSTOM cam = cam THAT MAY NOT WORK WELL!
I hope this helps!"
I hope this helps!"
10-15yrs ago I think there was a place for custom cams being not every combination of parts had been tried and tested. In 2017, 20yrs after the birth of the first LS platform, I do not see anybody reinventing the wheel on cam shaft design for a plastic intake 346 or 364 inch motors. The biggest change has been lobe design in the last 5yrs and most of the older cam designs were updated to the new smoother lobe stuff. So I agree...90℅ of most setups do not need a cam customs spec'd for their application because that setup has more then likely been replicated countless times and their is a cam out there on the shelf that will match up perfectly for your setup and goals.
One other thing: shelf Comp Cams are ground on CNC equipment in large batches. They are usually dead nuts correct. And Comp has fixed a lot of their issues with the cams that would gall and squeal.
The custom stuff is run on older lathes and may not be cut accurately or with the same finish to them. That's the issue with one-off stuff.
If you were going to do a Comp Cam... I'd only do shelf.
Custom would be Cam Motion as each one is cut the same.
thank you!!! Agreed!!
Thanks for sharing.
I've been eyeballing that BTR LS1 Stage 2 for over a year now but not wanting to pull the trigger till I see what this thing can do with bolt-ons. Doing all my pulleys and k-member this year and wondering if I should just do it while I'm there.
I would consider a shelf cam as one already designed and kept in stock or readily available from a performance shop or cam company, i.e. BTR stage 4, Comp XR 275 HR etc.
A custom cam for me would be designed as a one off for a specific combination when looking to maximise the abilities of that combination where shelf cam variations are limited and a unique grind would make a definite and significant tq/hp improvement (certainly not any Chev smallblock/LS engine these days).
In many instances of the "which cam should I get?" question asked a gazillion times on here the advice has been given to call (insert name here) for a custom spec. In 99.9% of those instances an off the shelf cam of some variation from any cam vendor/company would have probably done just fine. The gains with a "custom" grind would be none to minimal over a good shelf cam, my 2c worth
. Last edited by Jase01; Feb 20, 2017 at 06:48 AM.
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Back to the topic at hand. If that "shelf cam" wasn't designed in the last 3-4 years, you are better to walk away and find one that was. As previously mentioned we have come a long way in the last little while with respect to lobe design and valvetrain stability/longevity options. The "declassification" of information by members and vendors has increased buyer confidence in the procurement of a camshaft. Thankfully gone are the days of .6XX"/.6XX" 2XX/2XX 1XX+X - tell anyone the specs and I will off your family.
I would suggest, as others have, unique applications will necessitate a custom cam (ie. a max effort build) vs. the shelf grind (proven/safe/predictable).
Good thread.... some vendors/people don't off shelf cams such as Pat G. You have to fill out the cam card data sheet specifying weight, gears, tranny, stall, use of vehicle, compression etc..... He don't use comp cores at all anymore. All his cams is cut off a cam Motion core or a callies (Texas speed) core.
But the lobe profiles Comp has are pretty awesome. Lots of R&D in them.
And yes, it took them a while to come around on the cam core issue. But it wasn't the finish or the material that was the problem... And they looked at GM cores and the cores from Catepillar to discover the issue... yeah.
I've always agreed with this!!!! New users always fall for the custom cam bait trick! 99% of users are fine to let someone recommend them a proven shelf grind.
I don't think there'd be too many LS combos that haven't already been done before that would require really nutting out unique valve events/lobe area for a truly "custom" cam that's going to gain significantly over one currently available.
There was a "post your custom cam specs" thread a while back. Lots of people were running the same exact cams, which is a surprise to some. I had a close friend afraid to change ANYTHING about his car once he had Pat G spec him a cam. I still think he is an idiot for that one.
A cam doesn't care what it is called. An engine doesn't care what it is called. Turbo cam, nitrous cam, blower cam, N/A cam...the engine doesn't care.
All that matters is that the cam is correct for the application.
Great thread but this is the most correct statement of all and they were all good
