Cam gurus, how would this cam work?
Old May 17, 2017 | 03:57 PM
85Iroc's Avatar
Default Cam gurus, how would this cam work?
I have a sbe 346 in a 98 Camaro drag car. It currently has:
1-3/4" Kooks LTs with true duals dumped under seats
milled 241s
el torro 230/230 cam
LS6 intake and chris1313 ramair
underdrive pulley
glide with 5500 stall 8" converter
4.86 gear
275/60 radial
The pistons have been flycut .080.
I'm soon switching to fully ported 799 heads and fast intake. I'm not afraid to turn 7000+ rpm. May possibly throw a 100-150 shot at it, but it I'm NOT trying to set it up for NOS.
the car should weigh around 3100-3150 without driver
My question is how would this cam work with the new setup?
236/244, .618/.621, 110+3 lsa
What's everyone's opinions?
Old May 18, 2017 | 09:06 AM
Bspeck82's Avatar
I think you should keep current cam and invest in AFR heads first. Or get a heads cam package from them. But yes that 236 cam will make power 4500 and up.
Old May 18, 2017 | 11:55 AM
A.R. Shale Targa's Avatar
might be worth it to call Cam Motion and get a Low Lash Solid Roller
since elevated RPMs of drag car, little more stable specially if considering spray
Old May 18, 2017 | 12:54 PM
85Iroc's Avatar
i'm only asking how this specific cam would work with my proposed combo. I'm not "in the market" for a new cam, just thought this one was a good deal and might be worth some e.t./mph over my existing cam.
Old May 18, 2017 | 01:52 PM
Darth_V8r's Avatar
Moderator
That and is you're going to spray you'll likely want the exhaust valve to open earlier than your current cam
Old May 18, 2017 | 03:05 PM
85Iroc's Avatar
I'm switching over to a turbo combination this fall so I don't want to put a lot more money in this setup, that's why i was interested in this cam that i mentioned, because it's for sale cheap. I'm not setting the car up for nitrous, I'm setting it up to run all it will run on motor in the 1/8th, then may spray a small shot on top of it, with the understanding that it will not be the optimal NOS setup.
Old May 19, 2017 | 09:49 AM
Darth_V8r's Avatar
Moderator
I misread something. I was looking at the 230/230 thinking something else. Yeah, the 236/244 is going to run better all motor AND on spray. it's won't be a good turbo cam, but you are already considering new stuff for turbo anyway. You'll want to verify PTV on the 236/244 cam - especially the intake side. Mine is 237/245-112.5+2, and I had 0.080" clearance. That cam is on a 110 LSA and +3 advance, so you're going to be tighter than mine.
Daily driving will be rougher, but I get the feeling you're not too concerned with it.
Old May 19, 2017 | 04:06 PM
85Iroc's Avatar
Bingo. I will drive it down the road here and there but i drove my Iroc with the 572 on the road on a few occasions so I'm ok with it not having great street manners.
This whole setup will come out when I do the turbo, replaced by something 5.3 based.
Also, my pistons are flycut .080 so hopefully that will give me clearance. Guess I better measure just in case.
Thanks.
Old May 19, 2017 | 04:52 PM
speedtigger's Avatar
Old School Heavy
milled 241s
underdrive pulley
4.86 gear
275/60 radial
Doesn't look too bad at all. A nice step up over what you have now for your intended application.
