Is it necessary to tear down your engine to replace cam bearings?
Old May 18, 2017 | 08:49 AM
StorminMatt's Avatar
Default Is it necessary to tear down your engine to replace cam bearings?
I found a couple of rust spots on my cam. So I figured I would pull it to see if I NEEDED to upgrade the cam RIGHT NOW, or whether I could just let things slide for a while. It turned out the rust spots were the least of my concerns. The frontmost cam bearing is completely trashed, as is the corresponding journal on the cam. It looks like I need to replace both the cam AND the bearings to get the motor up and going. But while removing the rotating assembly would at this point be a fairly trivial affair, I would rather not remove pistons and have to honey and re-ring (the cylinders have GREAT cross hatch - I don't want to needlessly loosen the piston clearance by honing). Do I NEED to strip down the block in order to replace cam bearings? Or can they be replaced in a complete motor that is out of the car?
Old May 18, 2017 | 09:07 AM
ACAMS's Avatar
Yes, you should take the whole engine apart because if the cam bearing is bad, who knows what else is bad as they don't usually go bad.
There are holes that need to be lined up, and it may can be done, but you will be better off tearing it down and cleaning/checking everything.
Old May 18, 2017 | 09:12 AM
64post's Avatar
^^^Out and apart.
Old May 18, 2017 | 09:50 AM
squarles67's Avatar
Absolutely necessary no, should it be done...yes
No need to hone and re-ring just because you took it apart
Old May 18, 2017 | 09:52 AM
cookseyb's Avatar
The trash from the bearing and journal went through the whole oil system, I would disassemble and thoroughly clean everything, a ball hone and new rings would work with negligible clearance issues unless you get carried away. new bearing and lifters and you should be good to go.
Old May 18, 2017 | 08:05 PM
64post's Avatar
Doubtful you could use a cam bearing install tool with engine in, you need room for that.
Old May 18, 2017 | 10:22 PM
Engine is out but assembled.
Old May 18, 2017 | 10:35 PM
64post's Avatar
Oh , well then you're half way there.
Old May 22, 2017 | 07:31 PM
s57_s2k's Avatar
I have done it before I only removed the crank shaft. no need to removed the pistons and rods.
Old May 22, 2017 | 10:24 PM
ACAMS's Avatar
Me too, but it is not the right way, and for sure not the best way.
