Time For a New Cam, best option?
Old May 20, 2017 | 01:19 PM
Thatsilverbird's Avatar
Default Time For a New Cam, best option?
OK so this past wednesday my car began to have a slight tick coming from the engine so I drove it thinking maybe bad gas knocking or exhaust leak. Well it kept getting louder and more aggressive so i decided its probably lost a lifter, bent a push rod, or bent a valve. Anyways i think its time for a new cam and was wondering what would be the best one? If it was a a small block ford or chevy i could pick one out easy but not with these newer engines. The car is 2000 Ls1 Trans Am M6 with 113k miles, its only got cat-back, a K&N intake, and stage three monster clutch. It is also daily driven about 60 miles round trip. Id like to get some of that old thumping sound but not really looking for major power gains. MPG i would like to stay close to the same if maybe 1-3mpg less. If anyone has advice id like to thank you already! Really need to oder it ASAP as i need my car back, a 12 MPG truck sucks driving that much!
Old May 20, 2017 | 01:24 PM
HCI2000SS's Avatar
If you want the choppy sound but similar gas mileage I'd throw in a cutout along with something like a 228 style cam. This way you'll have minimal overlap but it will chop with the cutout open, and gas mileage won't suffer bad. It's one thought....
Old May 20, 2017 | 02:24 PM
Darth_V8r's Avatar
Moderator
That old school thump is overlap. It's really hard to get a lot of overlap AND good mpg without also ripping the heads off and milling for some compression.
For a basic install and go cam, I'd suggest cam motion titan 3 as a starting point. Titan 4 also good. Worth consider new lifters also
Old May 26, 2017 | 06:34 PM
Thanks for the options guys, i know that overlap causes the more aggressive sound i just don't know what cams for an ls there are? This is my first LS and computer controlled car. i can build one heck of a SBF or SBC! And i pulled the valve covers and it looks like a broke one pushrod and bent three more, or well the previous owner did the damage i just happened to have them finish off! But ill keep those cams in mind as it will get one eventually! Probably towards the end of the year or next tax season!
Old May 26, 2017 | 07:01 PM
Bspeck82's Avatar
I have a "small" cam with -1 overlap at .050 and with a magnaflow muffler, chop is muffled. Without a muffler it has a very noticeable chop to it. I prefer it this way, if I were to add cutouts it would be loud when I want it, (parking lots, car meets, showing off) or quiet when cruising. Or run a louder exhaust system, magnaflows are pretty quiet. Id check out Hooker blackheart true duals, those would be nasty. They run about 800 bucks and may need adj lca brackets...I think? Its up to you, doesn't take a radical cam to get a mean sound. Besides, do you really want to shake windows and run 11s?
Old May 26, 2017 | 10:28 PM
07NBSChevy's Avatar
For a basically stock LS1 the TSP 2224R or 224/228 .600/.600 are great daily driver cams.
The next step up would be a TSP 228R .600/.600 which would have nice power from 4,000 to 6,500.
If you decided to go with some longtubes you could step up to a TSP 228/232 .600/.600.
I would stay under a 228/232 unless you decide to go some with nicely ported heads.
Old May 27, 2017 | 07:47 AM
LS1121's Avatar
I installed this LS6 Corvette 12565308 very happy, great gas mileage and more power. It's a GMPP stock cam for a 2004 Z06, car runs great.
Old May 27, 2017 | 08:43 PM
98znasty's Avatar
This. Plus don't forget your upgraded springs, pushrods, and rocker trunion. Do the oil pump while your there too
Old May 28, 2017 | 02:40 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
This is our new high lift hot cam. Made 385/365 on an m6 car. doesnt need a stall or gears either!
Cam kit as installed is $515 or $585 with hd pushrods. Cam install kit is $60. Easy to drive, easy to tune, and alot of fun! Sounds like a much larger cam and doesnt kill you mpg either!
https://youtu.be/wSjWeEuRBhc
Ls7 Lifters are $95
Oil pump is $85
Head install kit with all new seals and head bolts runs $200 with new thrust plate also!
Old May 28, 2017 | 07:20 PM
Bspeck82's Avatar
Ls7 Lifters are $95
Oil pump is $85
And.....Valve events?
Old May 28, 2017 | 07:25 PM
The same as the reg hot cam jus with more lift as the name implies. 218/227 .600/.600 112+3.
A pair of 799/243s would make more power as would a bit more tuning.
