Please comment on wear pattern.
I found a knocking sound and eventually tracked it down to the right side of the motor. One of the rockers had some play. Swapping the rocker and pushrod did not fix the issue. I pulled the heads and guess what. The one lifter I can't get out of the bore maps up to where the noise is coming from.
Then I notice this wear pattern. Pulling the motor is going to set me back at least two months so I would like to get feedback if this is a show shopper. There is a definite wear pattern in the 6 o clock position of each cylinder. The honing pattern has been worn away. It is not detectable with my finger nail.
Can anyone comment on the best far forward? I am losing my mind over this. Is it best to ship this thing to a knowledgeable builder or is there someone near DC that can handle this kind of work? What do you guys think this motor needs to be right?
Lifter still stuck in bore BTW. Really stuck!
Guess I need a rebuilt? Would be a bad idea to throw in new cam and lifter set?
with the engine that far apart, id pull it, getting it out is part of a day then find your regional SCCA clubs web page, there is almost always a a forum talking about motor building. Typically there will be a builder or two who sponsors the club. The road race guys take no prisoners with engine builders.. Unfortunately the good builders are likely booked this time of year.. (Beginning of the season.)
Or google around for a sprint engine builder at your nearest dirt track,
Local drag strip web page etc.. All the same deal..
What oil do you use ? maybe your engine builder did not put oil on the cylinder walls for initial start up and that is why there is a longitudinal wear on the walls.
However, the valve train damage is a major point of concern. Not just because the need to replace the parts but because that kind of failure shouldn't happen when the engine has just seen idle.
I think I am leaning towards a manufacturing flaw with the lifter or something wrong with the aftermarket cam causing the failure.
