Is this cam bearing installed correctly?
My stock bearing was not clocked in this position. Both holes were down. On the tear down of my blown up motor I found the cam bearing in this position? Is this an issue???
The builder put one oil hole in the 11 o clock position and the other at 3.
My stock bearing had oil holes at 5 and 7 o clock.
Does it matter?
This thread discussed how they need to be lined up.
https://ls1tech.com/forums/generatio...ientation.html
Not my picture, but this is how they had to line up in my block.
Cuz starving the cam journal will only chew that particular journal up and might run a bit longer than expected.
Usually premature engine failures are related to bearing clearances in the lower end.
I've personally seen factory rods re-torqued with the original bolts and the big end was distorted by a full thousandth of an inch which needed resizing.
Thank you!
