Crank Question
Old Jun 24, 2017 | 01:38 PM
cnqrthedirt's Avatar
Default Crank Question
I have an LQ4 I had bored 030 over. I was going to use stock crank. My question is should I buy a used stock crank and when I get my pistons and rods bring it all to the machine shop and have it balanced or would it be worth it buying a remanufactured crank like this one...
Non-Sponsor Soliciting Policy
Thoughts?
Old Jun 24, 2017 | 01:45 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Use your stock crank. buying off ebay is a crap shoot for things like that. Your stock crank is good enough. quite a few times youd not need to rebalance for oversize due to the actual weight diff being negligible. not sure about .030 best way is to weigh the diff and find out. Your stock crank should already be balanced close to what you're looking at doing.
Old Jun 24, 2017 | 03:10 PM
07NBSChevy's Avatar
There is really no need to balance it, but if you are going for a performance build, it wouldn't hurt to balance the rotating assembly. Just make sure they don't balance it with the harmonic dampener installed.
Old Jun 24, 2017 | 03:29 PM
KCS's Avatar
KCS
Moderator
The pistons are for a .030" over bore so they probably weigh enough to need to balance the crank. I would balance it at least.
Old Jun 24, 2017 | 03:34 PM
07NBSChevy's Avatar
Ahh, I was thinking .003 over. You are probably right on 0.030" over and should be done. I forgot the LQ4/9 can go that far over.
Old Jun 24, 2017 | 03:48 PM
KCS's Avatar
KCS
Moderator
You never know though. People always mess up where to put that decimal place, talking about boring their block .30" over lol
Old Jun 24, 2017 | 03:57 PM
07NBSChevy's Avatar
Ya exactly, like boring their LS1 0.030" over. I see that a few times on ads for cars.
Old Jun 24, 2017 | 04:25 PM
Thanks for the replies guys and sorry for the late response. I don't have a crank on hand yet that's why I was asking if I should buy used and have it machined or buy an already remanufactured crank. Taking your advice into account (I'll end up getting it balanced - my rotating assembly) should I try and find a used crank in good shape that hasn't been machined yet and get it all done when I have it balanced and just stay away from a remanufactured crank?
Old Jun 24, 2017 | 04:52 PM
Like i said we have some cranks that are already machined and rough balanced close. for a .030 id recommend a balance but youll save money on polish and mic and chamfer holes as ours already has that done.
Old Jun 24, 2017 | 04:54 PM
Sounds good I'll go that route, whenever you get a price shoot me an e-mail.
Old Jun 24, 2017 | 08:15 PM
pantera_efi's Avatar
Default BW for a LS engine
Hi 07, MOST here provide BAD TECH.
The BW allows for a LIGHTER balance for a GOOD REPORT, MY method IS 2% OVER.
Your could BUY some STRONGER, "lighter" pins !
SURE .003" should be correct, thought is is DEPENDENT one PISTON WEIGHT.
THUS SAVE $250.00 AND FIT a STRONGER PIN.
Lance
Old Jun 24, 2017 | 09:03 PM
Seriously, as much as you presume to know lance you know very little and convey everything in the worst possible way. Is there some panteri efi decoder ring to buy?
Old Jun 24, 2017 | 09:19 PM
07NBSChevy's Avatar
Haha, I literally just spit out my drink when I read that last part.
Old Jun 25, 2017 | 10:15 AM
Default Piston Weight .003" OR .030" OVERBORE
Hi CN, sure your block is now a .030" OVERBORE.
WHAT I stated is you could have JUST HONED +.003 to +.007, SAVING that Bore Job COST.
THAT cost saving could have allowed you to purchase a "custom" LIGHTER FORGED PISTON.
THE BAD "tech" here is for you to BUY a "shelf" item, NOT ALWAYS the best choice for QUALITY at LOW COST.
YES use the crankshaft you have, the original item if in good condition.
Weigh a Rod/Piston from your old engine.
This is a Balance Shop task unless you have a "beam" scale with the rod bracket.
The BW (Bob Weight) would then be known.
The new piston, .030" overbore, could be less weight when the rings, pins, piston itself are added, thus a known value.
The piston manufacturer WILL provide this information if asked before a purchase in made.
This value ONLY needs to be less (2-3 %) or equal to the OEM weight.
They too will agree with the "tech"
THIS is a quality engineering practice.
Lance
Old Jun 25, 2017 | 12:42 PM
RockinWs6's Avatar
someone had to say it!
Old Jun 25, 2017 | 04:24 PM
2 - 3% is quite a bit of a swing even when you are talking over 1200 grams.
Thats why some pistons arent an issue like using 4.8 flat tops instead of 5.3 dish etc if you're talking that much.
Using a light weight pin wont help with anything either, esp of you wanna spend extra money on it and a custom piston set vs balancing.
