rebuilding engine, looking for torque
Old Jul 29, 2017 | 09:18 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
One dyno graph has it at 385/365 although i think itll be closer to 400/375 + honestly based off track times.
Old Jul 29, 2017 | 10:07 AM
Originally Posted by 07NBSChevy
That is not completely correct. While the 243 head did come before the 799 head, the 799 is supposedly a rougher cast produced by outsourced vendors. While the 243 heads are a smother cast produced by GM, both using the same mold from GM making the heads identical. You can visual see the difference between the two under close examination such as roughly casting lines and roughly ports on the 799 heads. Nothing noticeable unless looking for it.
Wow. Thank you so much for this info! Sounds like it would be a good idea to at least clean up the ports if not just port them, and THEN have an equivalent head to the 243.
Old Jul 29, 2017 | 02:59 PM
Darth_V8r's Avatar
Moderator
Just to clarify----
243 is die cast. 799 is sand cast. That's the reason for the smoother surface of the 243. They perform identically. The real advantage to 243 heads - if and only if you get them off a vette - is the light weight sodium filled valves. 799 is a fantastic head in stock form.
Hope that helps.
Old Jul 29, 2017 | 10:53 PM
Thank you for clarifying that. With 799's becoming very common, it's nice to know they have the same potential as the revered 243. And of course, as I said, with porting, no difference to speak of.
And yes, you DID help! Thanks again!
Old Jul 30, 2017 | 12:23 PM
omc8's Avatar
Originally Posted by NA99T/A
but would the 5.3 do better at bumping compression?
my budget is running thin so im just trying to buy a better set of heads then my stock 853's, im trying not to also pay for porting or milling heads. not at this point anyways.
So maybe the better question is if choosing between the two heads and not porting or milling which would better suit me?
thanks for the advice
To upgrade on budget you need at least $400, here are couple options at that price point. take 5.3 heads and freshen them up with new intake valves 50. good vj 250. mill 75. and bowl blend. Or Just buy stock 243s for 400 .
Old Jul 30, 2017 | 09:29 PM
NA99T/A's Avatar
well i should clear up what I meant. right now i was looking at replacing my stock 853 head with a new set of prc stage 2.5 5.3 CNC ported heads for 1300. when i mentioned budget I meant I cant afford to have more work done to set of 1300 dollar heads, as im already spending more than intended on my rebuild.
Old Jul 30, 2017 | 09:31 PM
Use the tsp heads they will work good for you
Old Jul 31, 2017 | 08:08 PM
NA99T/A's Avatar
so as far as the cam goes, if I said I wanted a cam
1. made for torque
2. wouldnt need revved past 6200rpm
3. has a choppy idle
3. didnt care about street manners
4. emmisions are not a issue
is the hotcam mentioned earlier in the thread still the best canidate to build the most torque?
Old Jul 31, 2017 | 08:13 PM
Darth_V8r's Avatar
Moderator
I'd look at the SNS2 torquemax from tick. That cam was developed by Martin smallwood and has an excellent track record and been unchanged for a long time.
Old Jul 31, 2017 | 08:51 PM
They werent designed solely for torque. It will make a good amount though. It was designed to be an alternative to the gm hot cam and promote more power with a bit higher lift and a brand new lobe design. It was made to be quiet, valvetrain friendly, and budget friendly. We capped the lift at .600 to keep worries away about valve guide wear and the "need" for roller rockers but also to use a nice beehive spring for budget.
If i were to design a cam for torque id add in a but more intake duration and more lift but then it would be like any custom cam.
The negative overlap does help with emissions and im sure the dyno graph will show that. Anything larger without a wider lsa to compensate is going to go into overlap territory and cost you on the emissions side.
Old Aug 2, 2017 | 08:07 PM
NA99T/A's Avatar
thanks darth v8r, I looked into the sns2 cam and it seems to be a perfect fit for what I want. An aggresive cam that is more concerned about torque and not cranking 6500 rpm to get it, plus its idle sounds great!
I still want to thank ws6store for all the input and I still intend to order one of your rebuild kits in the near future, along with some other your rpm speed rockers with trunnion upgrade, and a new set of lifters, cant decide between some ls7 or morels.
Old Aug 2, 2017 | 08:09 PM
  #32
NA99T/A's Avatar
and for heads I came across a local guy with a set of ported 243's with the z06 valves and new btr 660 springs. selling them for 900
that sound good?
Old Aug 8, 2017 | 08:48 PM
  #33
Zach-R's Avatar
I have similiar goals and parts as you. Interested to see how yours turns out. Ive got ported/milled 243s and the tick sns torquemax 2 cam. Hopefully i can get it all finished within the next few months.
Old Aug 9, 2017 | 06:24 AM
  #34
z-maro's Avatar
that sound good?
Depends on who ported them, was it a reputable shop? If it was someone like AI, TEA, etc then yes, if a home port job maybe not. Also are they ready to run or do they need new valve springs, seals, etc?
Old Aug 9, 2017 | 06:42 AM
  #35
HCI2000SS's Avatar
Like zmaro said it depends on who ported them. If done wrong they could hurt vs help
Old Aug 12, 2017 | 04:08 PM
  #36
wannafbody's Avatar
PRC Stage 1 heads are a great bang for the buck head. I'm not sure much is gained with the Stage 2.5 larger valve on a 3.9 bore.
Old Aug 12, 2017 | 04:40 PM
  #37
speedtigger's Avatar
Old School Heavy
Originally Posted by HCI2000SS
Changing the gear will help with your torque issue
This is an excellent suggestion. A set of 4.10 gears will do more for observed rear wheel torque than anything.
so like the title reads im about to be rebuilding my ls1. I bought the car a few months ago with a ms3 cam already installed but no supporting mods. I installed a edge 3800 stall convertor, then shortly after I lost all oil pressure. drained my oil and its full of metal...so i finally got the motor pulled out and after removing the valley cover I can see my ms3 cam is damaged.
so now that i know im replacing the cam also I think im gonna go a different direction with my build. im looking for the best cam/head package to make low end torque. not really wanting to rev past 6k. I figure for heads the prc stage 2.5 5.3 heads for a bump in compression, but im needing help with cam selection. I prefer a choppy idle but will sacrifice it for more torque. and im not worried about emmisions here.
any info is appreciated
The formula that I would recommend is some Trick Flow 220 CC as cast heads, Cam Motion Titan 4 camshaft and some 4.10 gears. More torque that your tires will be able to take!
Old Aug 12, 2017 | 05:40 PM
  #38
NA99T/A's Avatar
i bought a set of 243 heads with new btr.660 springs, and have plans of ordering the tick sns2 torquemax cam. I also plan to run a thinner head gasket to bump compression a little.
as for gears it currently has 3.73's and running a edge 3800 stall. If after the rebuild is finished I still want more then I will invest in some 4.10's.
Old Aug 13, 2017 | 02:34 PM
  #39
TrickFlowTech's Avatar
LS1Tech Sponsor
Our As-Cast 220's deliver 536/482 on our engine dyno. This was on a LS2 shortblock though. We don't increase valve size, but the bore is less shrouded than a LS1 which is worth about of 8 cfm or so over our standard rating. The rest of the engine was a Fast 90, 1 7/8 headers, along with full length 3" duals and flowmasters.
To give you an idea, the cam used for the test was a tfs-3060-2003. It's a 228/230 with 112 lobe separation and .585 lift and peaked at 6350 rpm. Compression was only 10.1:1 on our test engine, so you could certainly pick up power and torque milling the heads to 60cc and hitting 11.3:1
I generally back out about 13% to see approximate whp numbers. This would put it at 466/419 Tq. The F-Body exhaust routing can chew away at that, but I'd still expect 440/415 with minimal bolt ons.
Let me know if you have any questions.
__________________
