Ls1 Crank plug
Old Aug 8, 2017 | 12:20 PM
johnfin's Avatar
Default Ls1 Crank plug
In the correct p/n 24502262. Comes up as a water pump plug.
Old Aug 8, 2017 | 12:35 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
That is the right pn. It is used in a few v6 engines also. Most auto manuf use parts that are universal for other engines to save on prod costs.
Old Aug 9, 2017 | 12:39 AM
Jontall's Avatar
•Check the crankshaft rear oil gallery plug is not loose, damaged or leaking.
•If necessary, coat the new oil gallery plug (1) with Loctite™ 242 or equivalent.
•Install the new oil gallery plug to a depth of 31.2-31.6 mm (1.22-1.24 in).
Old Aug 9, 2017 | 08:36 AM
johnfin's Avatar
Default Pn
What is object number 1349302?
Old Aug 9, 2017 | 11:57 AM
Jontall's Avatar
It's just the picture ID in the manual so don't worry about it.. I removed them to avoid confusion. Your part number is correct: GM part # 24502262
This will help you a lot: https://www.mediafire.com/?40mfgeoe4ctti
Old Aug 9, 2017 | 12:02 PM
Jontall's Avatar
Also remember that the pilot bearing has 2 sides and the chamfered side of the bearing faces the transmission.
Old Aug 10, 2017 | 08:20 PM
johnfin's Avatar
Default bearing
I would think the chamfer would face the engine for ease of installation and the trans shaft is chamfered so its easy to install into the bearing.
Old Aug 10, 2017 | 08:31 PM
The chamfer which is more like a radius is only on the ID not OD.
Old Aug 11, 2017 | 02:19 AM
Jontall's Avatar
This is the only way that I can describe it to avoid confusion:
Faces transmission
Faces the engine
