Ticking sound with video
Old Aug 20, 2017 | 04:54 PM
cyberd0rk's Avatar
Default Ticking sound with video
I've been trying to figure out a tapping sound that bounces off of jersey walls and other cars. The top end of the valve train has been checked and I cannot find anything wrong, nor does the sound seem like it's coming from the top area of the motor or accessories. The sound definitely sounds like it's coming from the passenger side behind the front wheel. I took a video to try and get some opinions on it. Exhaust has been painstaking gone over to ensure it's not an exhaust leak. Anyone have any obvious solutions for this? I'm assuming it's a lifter ticking but I'm inexperienced with internals. Any chance this could be something worse like a crank or rod bearing?
https://streamable.com/0wv1t
Old Aug 21, 2017 | 05:21 AM
07NBSChevy's Avatar
Hard to really say, can you get a video in the engine bay as well. I have heard this before from an exhaust leak, from the plug wires arcing, as well as Lifters. So you have determined it is not an exhaust leak, can you get a mechanics stethoscope and determine a more pinpointed location? It sounds like a valvetrain issue and not a bottom end issue.
Is the car stock?
Did it recently start doing this?
Old Aug 21, 2017 | 05:39 AM
cyberd0rk's Avatar
I'm starting to wonder if my header flange isn't flat and I'm not getting a seal on the bottom side of the gasket. I replaced my exhaust gaskets a month ago because one blew out on the drivers side. I've used a stethoscope and haven't found an obvious location yet. The car is stock minus an exhaust and currently has about ~54,000 miles. It's been doing this for a few months now and seems to be getting more noticable (or I'm becoming more paranoid). I used the stethoscope on the valve cover and over thea areas of the block. Think I would have more luck taking the valve cover off, starting it and placing the stethoscope on the rocker bolts? Someone mentioned it could be a valve, possibly burnt, thats making the tick when it closes, and the noise is transmitting out the exhaust.
Old Aug 21, 2017 | 05:41 AM
fst100's Avatar
when did you notice the ticking sound? also when did you install the pacesetter LT headers?
Old Aug 21, 2017 | 05:54 AM
cyberd0rk's Avatar
I've owned the car for about 8 months and have but ~2500 miles on it. The headers have been on it since I bought it. I noticed the ticking sound 3 months ago. Since then I've down the following:
1) Replaced all exhaust clamps with band style.
2) Replaced manifold gaskets with Felpro
3) Tried running seafoam and Marvel Mystery Oil (hey why not) through the oil and changing oil hoping to free a sticky lifter.
4) Removed rockers and checked them and pushrods.
I've also been wondering if the ticking seems louder now after I messed with the rockers. Maybe I didn't set preload properly on the base circle and increased slack. I would have thought valve train noise would have been more obvious on the top end. I'm new to LS motors and have read plenty of spots where they're noisier motors thanks to aluminum block and heads with a plastic intake manifold, but I'm starting to question the boundaries of normal valvetrain noise.
Old Aug 21, 2017 | 08:30 AM
kinglt-1's Avatar
Hard to say...LS1 engines are just noisy in general being all aluminum with a plastic intake.
Old Aug 21, 2017 | 04:37 PM
cyberd0rk's Avatar
Alright so I took another listen with my 1/2" extension and I can hear the clicking through all 4 header pipes on that side, all sounding similar in strength. What could cause a similar tick through all pipes?!
Old Aug 22, 2017 | 08:47 AM
fst100's Avatar
possibly thin header material. my headers tick on my driver side and I k=just lived with it lol.
Old Aug 22, 2017 | 09:01 AM
cyberd0rk's Avatar
Currently I'm looking at replacing the exhaust manifold gaskets (again, they're only 3 weeks old), replacing the lifters, and replacing the throwout bearing. If those options don't fix my tick I'll probably sell the car out of paranoia.
Old Aug 22, 2017 | 04:34 PM
wannafbody's Avatar
After putting Hooker long tubes on my 2000 TA, mine sounds the same.
Old Aug 22, 2017 | 09:59 PM
kinglt-1's Avatar
headers tick...and they amplify valve train noises even worse on a all aluminum engine with a plastic intake as I already mentioned. You would know if it had a bad lifter...it's not something you second guess. A bad lifter causes a similar noise but it s much louder and intensifies with rpm. Put a hat on so you do not pull your hair out and go enjoy your car.
Old Aug 22, 2017 | 10:08 PM
qweedqwag's Avatar
Just did rocker, lifters, push rods, heads and header gaskets, mine is quiet as a church mouse.
Old Aug 22, 2017 | 11:18 PM
wannafbody's Avatar
I checked mine with a stethoscope and the injectors make a fair amount of noise. I think that is being amplified by the headers.
Old Aug 23, 2017 | 08:12 AM
cyberd0rk's Avatar
Alright I just purchased yet another set of header gaskets, this time Percy's. I'm going to go the extra mile and slather them in RTV and pray **** shuts up. I checked all my injectors and they seem to be equal volume on each head. It'd be strange if one side was amplified for some reason. I just can't get over the fact that these cars are normally loud with ticks and strange noises. Good thing is it still drives good and pulls hard
Thank you everyone for the input.
Old Aug 23, 2017 | 10:56 PM
wannafbody's Avatar
Report back.
Old Aug 27, 2017 | 01:07 PM
cyberd0rk's Avatar
Yesterday I replaced the exhaust manifold gaskets with a set of Percy's, did a compression test (all cylinders 185-190psi), and yet again checked pushrods and rockers. Nothing changed. I took an automotive stethoscope and checked all around and cannot isolate the ticking anywhere in the valve train, block, or transmission. Without the stethoscope I can distinctly hear the tick right at the passenger side collector. So today I put my leaf blower in the tail pipe and plugged the other, and sprayed down that collector with soapy water and didn't see any signs of leaking. Started to explore on LS1 tech and a lot of people say there heads are ticking just from the exhaust pulses in the thinner gauge metal. I bought the car with long tubes on it so I never got to experience the stock manifolds. Maybe I need to stop being paranoid and accept the logic that long tubes tick?
Old Aug 27, 2017 | 11:03 PM
wannafbody's Avatar
Double check your spark plugs to make sure they are tight
Old Aug 28, 2017 | 10:14 AM
cyberd0rk's Avatar
Found that solution a few weeks back. Plugs were tight. They're tight again fresh off the compression test now as well.
