Am I calculating compression wrong?
Old Aug 24, 2017 | 02:17 PM
blackfbird98's Avatar
Default Am I calculating compression wrong?
Trying to figure out what my compression would be for my lq4 setup and no matter what calculator I'm using it comes out weird? Or am I just reading it wrong ?
Old Aug 24, 2017 | 02:33 PM
98CayenneT/A's Avatar
The deck clearance number is wrong. Like my car the piston is out of the whole .007" so I would put that there and it calculated correct for me
Old Aug 24, 2017 | 02:34 PM
Try this one. It's pretty accurate...
https://www.uempistons.com/index.php...279b523a981cb8
Old Aug 24, 2017 | 02:35 PM
Old Aug 24, 2017 | 02:50 PM
What is it out of hole typically for an lq4?
Old Aug 24, 2017 | 03:17 PM
That I do not know. I know Ls1's are .005" - .009" and I measured .007" on my motor.
Until someone with more knowledge posts up I would have to imagine the Lq4 is in the same window of deck clearance.
The number you put in I'm assuming it's deck height and they are looking for clearance. (Piston out of the hole)
I think you would be fine putting .005" - .007" in for a rough idea.
Old Aug 24, 2017 | 03:29 PM
Ok I got it now it says 11:4
Old Aug 25, 2017 | 04:02 PM
farmington's Avatar
I thought that LQ4's had dished pistons.
Old Aug 25, 2017 | 04:33 PM
That's been my understanding, with LQ9's having flat tops for more compression, plus a different cam for more power to boot.
Old Aug 25, 2017 | 04:53 PM
LLLosingit's Avatar
My lq4 had dished pistons but didn't know what they measured... doing a search came up a couple examples that were actually measured and one said 6.7 dish and the other was 7.0 dish.
Old Aug 26, 2017 | 09:29 PM
sbcgenII's Avatar
Your gaskets thickness is .510 That is over 1/2" Should be .051
