LS6 cam or ??
This one only looks like this (and it is stamped/laser etched):
5308
416734
Nothing else....
Thanks,
ANYONE correct me if necessary. 2002 was the year GM changed from early to late cams
The ones that stood out for me were the LQ9 and LS2.
The LQ9 gained 40 HP while losing VERY little on the low end and the LS2 gained 78HP with not much loss on the low end.
The Zo6/LS6 5308 cam has a smaller base circle also...the Vette's that ran that cam, used longer valves to compensate.
Just a reminder...if you run one in a "standard height valve" LS engine, you will need longer pushrods.
