Cam question. Which one of the two???
Old Sep 18, 2017 | 09:49 AM
jimmyp3353's Avatar
Default Cam question. Which one of the two???
Being somewhat if a novice when it comes to valve events and picking the right cam for the application, I figured I would come here to ask the question. I have a 98 Camaro with a SBE LS1, 243 heads, victor Jr. carb single plane manifold, 750 mech secondaries holley carb. TH350 with a 4000 stall. 4.11 gear with a 28in tall drag radial. Has about 200-300lbs of weight reduced. Car is a dedicated drag car that I drive on the street occasionally. I have 2 cam choices on my shelf. One being the MS3, and the other being a custom grind 234/238 .629 .629 112+4 (was in the shortblock when I bought it). What would be more optimal for my setup as a drag car. 1/4 mile? I know contacting one of the vendors would be optimal, but if I spend anymore money on this thing my wife will kill me LOL.
Old Sep 19, 2017 | 08:59 AM
jimmyp3353's Avatar
Anyone?
Old Sep 19, 2017 | 10:59 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
either will be pretty close but the ms3 on a 111 is what i would choose.
Old Sep 19, 2017 | 02:23 PM
jimmyp3353's Avatar
The MS3 I have is 237/242 .603/.609 112LSA
Old Sep 19, 2017 | 02:30 PM
Are heads milled?
Old Sep 19, 2017 | 02:53 PM
jimmyp3353's Avatar
Are heads milled?
They aren't
Old Sep 19, 2017 | 03:13 PM
Youll be fine with the ms3 cam then.
Old Sep 19, 2017 | 03:41 PM
jimmyp3353's Avatar
Had it in my other LS1 with a similar setup (different rear gear) and I wasn't really all that impressed with it. The thing made no power at all until like 5000-5500 RPM and I had to spin it over 7k. 241 heads though. really wasn't impressed with the track times either. I'll give it another go though if you think it will work better.
Old Sep 19, 2017 | 03:49 PM
00pooterSS's Avatar
I would vote MS3, but you said you don't like the rpm range, what about advancing it a degree or two to bring the power in sooner? Of course you'd need to be watch even closer for ptv clearance on the intake valve. Maybe one of the cam gurus can comment on that.
Old Sep 19, 2017 | 04:49 PM
Ptv close as it is. They come on strong above 3k. Thats the nature of the duration and lsa tho. A 111 or 110 with ptv checked would prob suit you better but the cam is good. Carbed setups are quite diff from fuel inj in those apects.
Old Sep 27, 2017 | 11:19 AM
stevemk85's Avatar
def what he said
Old Sep 27, 2017 | 11:21 AM
stevemk85's Avatar
Yes indeed afasdfsadfsadfsadfsadfsdafasdfsdaf
Old Sep 27, 2017 | 11:32 AM
A.R. Shale Targa's Avatar
I'd sell both of those to fund getting the right stick from a vendor
One that clears the pistons without worry or notching
One that works with the dinosuar (controlled fuel leak) of a fuel mixer
AND has enough street manners so you don't get spanked by some old TR224 combo where the race is over in 600 feet
Old Sep 27, 2017 | 11:45 AM
stevemk85's Avatar
hello poop
Old Sep 27, 2017 | 02:43 PM
Originally Posted by stevemk85
hello poop
Hello TROLL!
Old Sep 27, 2017 | 02:47 PM
Darth_V8r's Avatar
Moderator
This^^
