Ls main caps
Old Sep 23, 2017 | 04:44 PM
Bssmith11's Avatar
Default Ls main caps
I'm having issues breaking main cap bolts during assembly. I am using 15ft lbs of torque. I have purchased new bolts with same issue! Help would be greatly appreciated.
Old Sep 23, 2017 | 06:12 PM
MY_2K_Z's Avatar
Buy a new torque wrench.
Old Sep 23, 2017 | 06:19 PM
Bssmith11's Avatar
I did same result!
Old Sep 23, 2017 | 08:32 PM
slogo's Avatar
Your not confusing 15 with 150 are you, Because 15 ft # won't break a main bolt,
somethings not right here, are you having to put some strength on it to achieve the
15#? 15# is barely anything at all.
Old Sep 24, 2017 | 11:26 AM
pantera_efi's Avatar
Default Bolt Torque TTL OR ???
Hi Bss, could you state the tightening method AND the bolt/stud fitted ?
Lance
Old Sep 24, 2017 | 08:39 PM
MY_2K_Z's Avatar
Agreed 15ftlbs is barely snug, you absolutely are doing something wrong.
Old Sep 26, 2017 | 05:14 PM
00pooterSS's Avatar
It is VERY hard to feel the click of a click type torque wrench at low torque levels and you'll usually go way past it waiting for the click. At higher torque the click is a very adamant click, at low levels it doesn't really click it just kinda pops over. You need to get used to the feel of it first.
When I have to use very low torque like that I clamp the square of the torque wrench in a vise and lightly pull on it until I get the feel down and then I go over and torque the bolt.
When using that low of torque try stabilizing the wrench and then pulling it with one finger, that might help also.
Old Sep 26, 2017 | 07:34 PM
farmington's Avatar
try using a 3/8" drive torque wrench instead of a big boy
Old Sep 26, 2017 | 08:48 PM
You are referring to the 10mm side bolts, not the actual main cap fasteners, correct?
Old Oct 3, 2017 | 07:45 AM
youngengines's Avatar
That's what I was assuming too, surely he is referring to the side bolts.
