Compression woes. What am I missing?
Old Sep 25, 2017 | 08:35 PM
hankfan79's Avatar
Default Compression woes. What am I missing?
I have used 2 different calculators and come up with 1.38 which has to be total BS!
Here is what I know:
9.240 Deck Height
6.125 Rod
73cc head
-4cc Piston
4.030 Bore
.051 Gasket
3.662 stroke
What am I missing?
Old Sep 25, 2017 | 08:43 PM
98CayenneT/A's Avatar
Where you have 9.24 for deck height, they want to know how far out the hole the piston is.
Like on my Ls1 it is .007"
Old Sep 25, 2017 | 08:47 PM
If you are running flat top pistons and I put your info in with a deck height of .007" I get 10:1 CR
Old Sep 25, 2017 | 08:51 PM
Just saw your 4cc pistons and I put your info in again and got 9.6 : 1 CR
Old Sep 25, 2017 | 08:56 PM
hankfan79's Avatar
Well damn. I am trying to get to at least 11:1 without a head swap.
Old Sep 25, 2017 | 09:00 PM
Have your heads milled down
Mill the heads down .060" and run a .040" head gasket should get ya there
Old Sep 25, 2017 | 11:21 PM
JimMueller's Avatar
9.240 Deck Height > I used -0.007 instead
6.125 Rod
73cc head
-4cc Piston
4.030 Bore
.051 Gasket
3.662 stroke > Is this a typo'ed 3.622 or is it really 3.662?
Gasket bore? I'll guess 4.040
With the assumptions above, I get 9.778 static compression. Milling the heads to 63cc (~0.055") will net you about 11.1:1. I'd leave the gasket at .051 since that'll put your quench around .044. You can get a thinner gasket but then you'll be on the bleeding edge of safe quench.
Old Sep 26, 2017 | 06:35 AM
LS1MCSS's Avatar
Stroke should be 3.622
Old Sep 26, 2017 | 08:08 PM
hankfan79's Avatar
Yes it was a typo. Thank you.
Would milling that much cause me to have intake fitment issues?
They are mahle flat tops with valve reliefs. -4cc
I believe by the time I pay to mill these heads, it might be cheaper to pick up a set a used 243's.
Thanks for the input guys.
Old Sep 26, 2017 | 08:24 PM
I would say you would probably have intake seating issue.
Could have the intake shaved also.
Or just go with the 243's.
Have them milled .020" - .030" and run a .040" head gasket and you will be around 11:1 CR and not have to worry about intake fitment.
