Max Effort LS1 cam recommendation
Bad news tho... I sent my converter back to PTC to have them tweek it just a bit as far as tightinging it up just a bit to get back the mph I lost with it. Well they tightened it a little too much. Gone are my 1.30 60ft's could only pull 1.35-1.37. Even bumped up launch rpm... F*#%!!!!
To anyone reading this make sure if you are going big cam/intake you have a big loose *** converter or not afraid to dump the clutch at high Rpm's. If not you are wasting your time and $$$$.
I'm gonna pop it back out and send it back to get loosened then I believe I can see the cam and intakes full potential. I'm getting tired tho and ready to go turbo lol. N/A is a tough game to play
Aftermarket castings CAN be better by miles BUT sometimes they make you use special setups etc vs stock castings. Or require additional machining because they arent really universal fit. Ive had some issues with a few heads due to this. Sometimes they are fixed later on in casting revisions, sometimes not.
I don't have that data. Probably should tho. I run any of the n/A shootouts around and World Cup finals race.
Need stock castings for the class I run.
