lq4 arp head bolts over torqued
Wondering if anyone else has done this, bought arp head bolts and used there ultra grease provided. I have never used arp stuff before and didnt realize the torques were different. I used the factory torque and then the 90* and 70* final pass..... ended up somewhere around 115 ft ibs and was then told they should be 75 ft ibs for the arp stuff. Will it hurt anything to just leave it and run it or do i need to put new gaskets on and retorque to the 75??
Moderator
Well F*@#! First time I have heard this. So yup. I DID IT!. My **** is all at factory specs. I got my headbolts "Used" but never "used". They came with the box, but I didn't get any instructions, so I used ultralube or whatever that arp grease is, and followed factory specs. I had no idea, they would be different. My motor has been together for a little over a year. Planned on throwing boost at it here soon. NOW, I gotta wonder WTF to do.
That's MISTER MODERATOR
Had this been an aluminum block, you would've pulled the threads long before you'd hit 115.
The only head (and main) bolts that get torqued (or TTY) the same as stock bolts are stock bolts.
Anytime you move to an aftermarket fastener, the maker's values need to be followed.
I doubt you damaged or stretched the bolts, they're 200,000 PSI rated. I would inspect the bolt landing faces on the heads, some of them are hollow underneath where there are coolant passages.
If all is well, purchase new head gaskets. As much over torqued you say you went, they're shot.
