Piston to valve clearance ?
Old Oct 10, 2017 | 08:47 AM
87coupe6.0's Avatar
Default Piston to valve clearance ?
Hey everyone.i building a lq9 and my current cam is a tsp 624 614 233 239 with 111 lobe seperation with 823 heads and .040 compressed cometic head gaskets.with this combo have any ptv clearance issues? Also what kind of power can I expect from this combination?
Old Oct 10, 2017 | 11:29 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Youre gonna be VERY close. Depends on the icl.of your cam but if its 109 or less youll want to double check.
Old Oct 10, 2017 | 12:05 PM
87coupe6.0's Avatar
Well my 40 compressed hadn't came in yet so had them switch to the standard .051.cam is a 110 icl
Old Oct 10, 2017 | 12:09 PM
That will help but youre still pretty close. Definitely want to make sure on your pr length as well. A 231 would give you quite a bit more clearance but you should be ok.
Old Oct 10, 2017 | 12:19 PM
87coupe6.0's Avatar
Pushrod length shouldn't change should it?should just be the stock 7.4 right?
Old Oct 10, 2017 | 12:21 PM
With a cam that is close on ptv it would be best to double check that.
Old Oct 10, 2017 | 12:31 PM
87coupe6.0's Avatar
Ok thanks for your reply
Old Oct 10, 2017 | 01:14 PM
A.R. Shale Targa's Avatar
Are these the L92 big valve castings ??? 2.165" intake valve
IMO that would most likely be too close with either the .040" or the .051" gaskets
Bringing that intake lobe back to 230 or 229 @ .050" would buy you some safety net
Old Oct 10, 2017 | 01:18 PM
I have personally seen a 233 used if around a 110 or higher icl with a good margin for ptv.
Old Oct 10, 2017 | 02:49 PM
87coupe6.0's Avatar
Yeah these are the big valve heads.texas speed seems to think it should have plenty of room.he said the biggest cam they put in a lq9 was 23?-248 duration
Old Oct 10, 2017 | 03:03 PM
Every degree after 231 is the point of diminishing returns on ls3 heads on an lq9 piston esp with an early icl.
Old Oct 10, 2017 | 04:52 PM
Buddy of mine ran the TSP 231/237 stick in his LS3 however the aluminum block grows or "swells" more than the iron block stuff so at operating temp he did have a few more thousandths but it was still tight....around bare minimum numbers IIRC
Another component in this equation is the sloppiness of the timing chain since the cam can be ground in the right range but if allowed to move around too much can also cause issues.
Guess I'd hate for the OP to even shave his heads a few thou and run into issues.....most would say "hey the junk yards are full of iron block donors" but lets face it, eventually they will be gone......
Not trying to argue with any pros here just hate seeing any "My S#it's F*cked" threads.................
Old Oct 10, 2017 | 04:57 PM
87coupe6.0's Avatar
Yeah mine is a iron 6.0 block with a new timing chain so I'm hoping for the best lol
Old Oct 10, 2017 | 05:20 PM
That is why the pushrod length is important on this setup.
Old Oct 10, 2017 | 05:22 PM
87coupe6.0's Avatar
Right on thanks
Old Oct 10, 2017 | 05:58 PM
01ssreda4's Avatar
Check it, that will be close, possibly .100 or less on both sides.
Old Oct 10, 2017 | 06:10 PM
87coupe6.0's Avatar
Definitely will.appreciate all the replies.
Old Oct 12, 2017 | 07:34 PM
rpturbo's Avatar
Running a little close on the intake is one thing, but don't tempt that exhaust side too much, remember, thats where the "chase" happens.
