How To: Lapping Your Valves At Home
These heads were taken to a machine shop. They were cleaned and milled lightly but no other work was performed. The bill was around $80.
Here's an intake valve. Notice the silver streak around the lower edge. That's where it seals to the valve seat in the head. We are gonna freshen that surface and hopefully widen it some for a better seal.
Take your compound, and spread it like so. Doesn't have to be perfect.
Stick it into its hole and clamp your drill onto the stem so you can use the drill to spin the valve in the head.
Use the slow speed setting on your drill, and move it in and out (on and off the seat). Wow what a difference 20 seconds makes.
Comparison.
The sealing surface in the head.
Exhaust valve comparison. A little pitting on them is normal and nothing to worry about. Once i mate a valve to a hole, it stays there. I dont move it around once its been ground in. Also make sure you wipe as much of the compound off the head and valve as you can when youre done and hit the valve stem with some wd40 to help it slide in the valve guide easier.
Thats it, repeat the procedure for all 16 valves, makes sure you have a nice even band around each valve and you're good. If one looks off or not even all the way around check the valve and see if its bent slightly. Any questions just ask.
Biggest snag for a first timer is to make sure you get all of the lapping compound off the head and the valve.
Great info 01ssreda4
