Can I get the heads off with head studs in place?
First time yanking heads off of any LS engine.
Car is a 2000 Trans Am. I have it down to the long block, ie; everything removed except the heads themselves. I see there are head studs, so just wondering if the heads will clear them for removal?
I learned the hard way on my GTO which has much more room for head removal. Once it was out on one side, the other studs remaining made it hard to slide the head back on without doing additional damage. Beer didn't help either lol.
Love the last sentence, lol...
I'm just waiting for the clock to tick away another hour or so, and then I'm yanking these Frankenstein ported Trick Flow heads off...Since they're just shy of 3 grand, I will remove the studs FIRST...well, technically 2nd...I plan to break the seal, lift the heads up a little bit, to let most of the remaining coolant run out all over the floor, so I can track it all over the place...then remove the studs and heads...
FWIW, I was able to easily get both heads off without removing any of the studs. Had at least 2" of clearance.
Had a blow out on Cylinder #6. No damage to the head or block, according to my straight edge.
It HAD Fel-Pro PermaTorque MLS 1161L-053 gaskets on both sides.
I'm replacing them with GM, LS9 head gaskets
Any opinions on this particular gasket??
I will NOT be trying 22# of boost again, LOL...
Gonna cap it off at 10-12 and find out why my methanol stopped spraying...
