Junk Pile 4.8 freshen up
Old 12-29-2017 | 08:45 PM
  #41
A.R. Shale Targa's Avatar
Lovely beginning
Much better
Old 12-29-2017 | 08:47 PM
  #42
All clean now
Apparently nearly 200 K bearings
Old 12-30-2017 | 10:55 AM
  #43
After
Before
Old 12-30-2017 | 02:31 PM
  #44
Got the barbell out and a few galley plugs<br/>Then Milwaukee grinder wire wheel cleaned all <br/>The gasket mating surfaces
Seriously disgusting is covered; and then some
Old 12-30-2017 | 02:35 PM
  #45
After steam pressure cleaning for an hour<br/>Hand held wand works great but quite messy
Considerably better here
Back side
Bottom end
Front end
Old 12-30-2017 | 02:50 PM
  #46
That’s impressive for sure. Looks as good...or better actually, than shops I’ve used to clean parts.
Have you put a mic on anything yet, to see what needs to be done?
Old 12-30-2017 | 06:15 PM
  #47
Karlw's Avatar
Originally Posted by A.R. Shale Targa
After
Before
Did you fully disassemble those lifters when you cleaned them? If not there is a lot of garbage still hiding inside!
Old 12-30-2017 | 06:18 PM
  #48
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Those look like ls7 delphi lifters not the oe eaton bodied lifters so they look to have been replaced recently. Id check the cam, make sure its actually stock.
Old 12-30-2017 | 06:53 PM
  #49
Backside of the main bearings dated 02/99
Cam had 8 numbers. Four over Four in configuration on the rear of the cam
So. Likely OE
Old 12-30-2017 | 06:56 PM
  #50
Well darn then.
Old 12-30-2017 | 09:26 PM
  #51
gjestico's Avatar
That's got to be some aggressive cleaner to take off the brown stain. Solvent (paint thinner) wont do that alone. Good work !
Old 12-31-2017 | 10:59 AM
  #52
Haven’t measured anything just yet and thanks for the props
It does work really well. My hands are sore for days after. Lol
Yep. Sure did pop the ring out and fully cleaned all the black crud from inside
Only have a few done so far. Rest will happen after the new year.
Thanks for the suggestion
Old 12-31-2017 | 06:32 PM
  #53
Rods AND mains Mic very consistent
rods...............2.0994"
mains.............2.5583"
Old 01-01-2018 | 11:03 AM
  #54
cookseyb's Avatar
Looks like you are doing a great job of cleaning! Looks like this engine has been opened up before? the brass block plug has pipe wrench-Channel lock teeth marks on it? I heated the one on my similar mess then took the proper hex wrench to it and it came right out.. Lotsa crud behind it. I used oven cleaner on the outside of the block and it worked with some elbow grease...Keep at it!!
Old 01-01-2018 | 08:41 PM
  #55
1FastBrick's Avatar
In to see which way you go with it.
Old 01-08-2018 | 08:04 PM
  #56
Well I gave my buddy the potential budget on making this wreck right, and he toyed with the idea of replacing his wife’s 230,000 mile 5.3 in her 2002 Suburban, but ultimately picked up a good used LQ4. After seeing all my time invested so far he said,”It’s all yours man, free core”
So it will sit for a while till I can get back at it with some cash. Sucks but I now feel like it deserves another life. Like it’s some kinda personality or something. Geesh, I have an addiction
Thinking I’m gonna start a new AA program for Automotive Anonymous
Old 01-08-2018 | 09:25 PM
  #57
1FastBrick's Avatar
Stay Away from me...
Well since it was free, Which direction would you like to go with it?
Old 01-08-2018 | 10:58 PM
  #58
My next acronym for all Ya’all..CAF..cheap as F$@K
Again because it’s free.
Don’t have a car for it and it might be difficult to even break even trying to market a 300 inch Mill. Did some finagling today so we shall see.
Seems quite unlikely that I could do this for under $750 bucks. And while I’m thinking about it; gonna Hit this dude up for my other free 862 casting head.
Old 01-08-2018 | 11:00 PM
  #59
1FastBrick's Avatar
My next acronym for all Ya’all..CAF..cheap as f$@K
Seems quite unlikely that I could do this for under $750 bucks. And while I’m thinking about it; gonna Hot this dude up for my other free 862 casting head.
But 706's are the new best heads...
Old 01-08-2018 | 11:03 PM
  #60
1FastBrick's Avatar
BTW is the cam core the 0967 ???
Quick Reply: Junk Pile 4.8 freshen up
