Junk Pile 4.8 freshen up
Old 01-21-2018, 02:53 PM
  #101
94ls1's Avatar
Originally Posted by A.R. Shale Targa
You “might” have too many cars dude; LOL....
People liked the Katech heads build for that thirtieth M6 car of yours. Remind me to update that thread once Tom gets some wheel numbers on that one.
So that silver 99Z parts donor car of yours could end up being a low buck drag/turbo combination in the future ??? If that’s the case, we know this pile will be cheap and you could post some pics of that whip to this thread.
Might actually make a unique build thread that went from free junk to buyer/user with multiple inputs. Kinda silly but cool as well
Is "too many cars" a thing?
Yeah the 99 SS car that I bought for parts is going to become a budget turbo build as long as it's in good enough shape once I start tearing it apart. I will definitely know more within the next couple months when I get time/motivation to pull the parts needed for the 97.
Old 01-21-2018, 09:30 PM
  #102
A.R. Shale Targa's Avatar
Cool beans. Still need to add like three more cars to your profile there so others can fully understand the magnitude of your automotive disorder
Old 01-23-2018, 06:29 PM
  #103
My home made pin stop contraption
Little heat. Seal was toast on the shop rose bud; So had to Jimprovise
Desired stop depth set. Piston facing the correct direction, trusty pin Driver in place
All done. Bout twenty minutes total. SWEET
Old 01-23-2018, 06:53 PM
  #104
1FastBrick's Avatar
very creative! A+ for effort
Old 01-23-2018, 08:04 PM
  #105
Received 3,110 Likes on 2,425 Posts
And yet ANOTHER shot at us witnessing the SHEER GENIUS of A.R. Shale Targa! I'm not sure I can handle much more of this... some body get me a Mountain Dew....
Good stuff AR!
Old 01-23-2018, 10:23 PM
  #106
Good stuff AR!
Killing me guys. Had quite the chuckle picturing the new Dew commercial with that goofball acting all Hot while Junior stands there like WTF
All seriousness though; thanks a bunch !!! Your interest fuels me
Heads getting Milled thirty five now to get down to about 55cc
Block getting bored, honed, and decked next. Praying that thirty cleans up that fucked up cylinder. Doubt it but it’ll be close. Can’t wait to paint it. Always my favorite part for some juvenile reason....
Meanwhile the next owner of this Lil’ Mill is saving his pocket change and watching from afar.
Old 01-24-2018, 11:30 AM
  #107
Glad you liked it AR, good luck with it man!
Old 02-02-2018, 11:34 PM
  #108
Should CC in the neighborhood of 55 after a pretty substantial milling
Not great lighting but surface finish is really nice
Old 02-03-2018, 11:24 AM
  #109
1FastBrick's Avatar
Let us know on the CC
Old 02-03-2018, 01:41 PM
  #110
cookseyb's Avatar
What gasket will you use with those "Notched" heads milled that much?
Old 02-03-2018, 02:08 PM
  #111
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Wow, just wow.
That DIY piston stop is epic!
Old 02-03-2018, 11:00 PM
  #112
Will do Gotta get those three broken manifold bolts out. Lap the valves in again then clean and put together with new seals and springs
Not too certain. The replacement ones look like bore matching graphite
Originally Posted by mOtOrHeAd MiKe
Wow, just wow.
Thanks man. Much appreciated
Dropped the block off at the Machine shop today
They plan to offset bore the few nasty rusty cylinders if needed to insure they clean up well.
Old 02-04-2018, 11:47 AM
  #113
cookseyb's Avatar
Put a 3/8 washer over the broke bolt, use duct tape to hold it, weld it to the stud then weld a nut to that, cool it with penetrating oil an un screw it .. Works for me every time..
Old 02-04-2018, 12:29 PM
  #114
Good idea. One is slightly sticking out. The other two are recessed. Could end up drilling and easy out extractor. We shall see soon
Old 02-04-2018, 01:01 PM
  #115
Best guess as of now before CC’ing the chambers or finding out how much the block gets decked to clean up nicely. Should end up pretty boost friendly with the factory .500” camshaft
Old 02-04-2018, 02:56 PM
  #116
The Cartel's Avatar
I've had to build up weld on the broke bolt as well. Usually the heat from that breaks it loose pretty well. Then just a set of vice grips can unscrew it
Old 02-04-2018, 11:39 PM
  #117
LS1Tech Premium Sponsor
tech@WS6store's Avatar
We have the notched mls head gaskets at .053 ct.
If youre interested let me know. we keep 10 sets on hand
Old 02-05-2018, 08:43 PM
  #118
Good to know. Thanks. Some minor searching found the Fel Pro 9292. Not even certain that’s the correct one but looks similar to what came off
Old 02-05-2018, 08:47 PM
  #119
Slight update today. Did some expert bolt extraction.....3 of them to be exact
The “easy” one.
Kinda recessed
Buried
Old 02-05-2018, 08:54 PM
  #120
Thee arsenal 5/16” coarse
Start with a two step blob from the wire feed
Enough to hold the nut
Three quick “1 second” zaps to fuse the blob to the nut
Quick Reply: Junk Pile 4.8 freshen up
