Junk Pile 4.8 freshen up
Old 02-10-2018, 01:00 PM
  #161
A.R. Shale Targa's Avatar
That’s fricken cool. Not sure what’s better the shiny patina or the lavender covers.
Hope the clear coat doesn’t turn yellow. Then again who cares. Lol
Old 02-10-2018, 03:12 PM
  #162
Received 3,507 Likes on 2,162 Posts
This just keeps getting better and better!
Carry on!
Old 02-10-2018, 04:19 PM
  #163
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Thanks! It was a fun exercise - most people take these things way too seriously. All of the paint should hold up fine as it is Rustoleum engine enamel and is good to 500 degrees. The purple came out of a leftover can of Metal Cast we used to decorate some metalwork in our daughters' room. A good way to get the kids involved is making it visually appealing.
Old 02-10-2018, 04:29 PM
  #164
LS1Tech Premium Sponsor
tech@WS6store's Avatar
Any idea when the hammer tone bomber will run?
Old 02-10-2018, 05:13 PM
  #165
94ls1 can chime in. He will be purchasing this engine when finished
Little Brownie is for one of like six cars that he has going; busy fella
My guess is not till summer before he gets on it. Usually moves pretty well once it’s front and center
Old 02-10-2018, 05:42 PM
  #166
We may have a nice cam for it soon.
Old 02-10-2018, 06:31 PM
  #167
Received 3,110 Likes on 2,425 Posts
Any specs you'd be willing to share??
Old 02-10-2018, 06:38 PM
  #168
Developing 5 or 6 lobes. Part of our new SCREAMER line of cams. Made for high rpm. Lift varies from .600 to .625 so not ultra high lift but may have some .635 or so not 100% yet. We will have a 225 lobe, a 233, 239, 243 and 249 lobe so far. Lots of lobe area but easy ramps. designed to use a 1219x or better single or any dual spring.
Likely we will have a small displacement up to (5.1l 3.905x3.268) and a larger bore/displacement cam (like for the 333 and larger)
Should be interesting. A good amount of adv duration on each also.
Old 02-10-2018, 07:19 PM
  #169
I'm guessing you're working with some cam people here. Sounds good!
Old 02-10-2018, 07:34 PM
  #170
94ls1's Avatar
I'm hoping later this year. I have a few other irons in the fire right now.
Old 02-10-2018, 09:20 PM
  #171
Little Brownie will stay 99Z cam/blue springs. Basically a sacrificial lamb to get the car and functions worked out. He has an LQ4 to replace it with that I’m hopeful he’ll let me tear into at some point. Got another buddy of mine who is either gonna pop a 4.8 crank or a factory stroke in his LS3 Block for a blow thru BW S475 setup. Definitely post what you come up with. Might wanna keep lift at or under .600” since 95% of these builds use the factory rockers That tip geometry says “uncle” around .585” net valve movement
Old 02-11-2018, 12:10 AM
  #172
Found this old pic that I never posted. Sorta like a magazine shoot. Just find it hilarious how nice a stock set of 6.275” factory rods can look after simply cleaning
Old 02-11-2018, 07:39 AM
  #173
Don't tell me that... the cam in my wagon is .627"/.612" on Straub bushed stock rockers arms.
Old 02-11-2018, 08:55 AM
  #174
Plenty factors involved. The shorter base circle of the cam helps tilt the rocker back but head milling and thinner gaskets hurts. Push rod rocker and valve deflection removes about .020”-.025” which is why I said net valve movement
The rocker tip pad has its arc and pushing it .100” more than the factory cams gets sketchy.
Old 02-11-2018, 11:24 AM
  #175
Cam bearings are in
Old 02-11-2018, 11:48 AM
  #176
TBH i haven't seen enough of an issue with wear on stock guides to do anything less than .600. I may run a few tests, but so far no complaints about the tsp cams. Nearly their entire line up has .600+ and most of BTRs as well at least on the intake side.
Lots of irons in the fire also, just seems a shame to tell people if using dual springs please shim the hell out of them if there isnt a huge need to. Duration at 6000+ helps alot but lift will as well imo. Pack it in to push it out...you know how that goes.
Old 02-11-2018, 12:12 PM
  #177
You’re right the guides and valve stems hold up well. It’s more the rocker tips and valve tips that get ugly
And .600” theoretical lift ends up closer to .580-ish net valve movement after all the deflections.
And I usually put minus locks on to set springs close to that “60 from bound” that makes them control better AND last longer
Old 02-11-2018, 12:39 PM
  #178
We will offer them with an 11/32 pr hopefully to get the best out of what we are wanting to accomplish with minimal modifications and a decent budget. Im going to run either the Pac Psi or Manley beehive with them for testing. After comparing everything the Manley seems like my top choice though for this one.
I keep mucking up your thread. Documentation is spot on. Keep up the good work!
Old 02-11-2018, 01:03 PM
  #179
Now I am nervous. SLR lifters, 11/32" push rods, and rocker bushings don't seem to leave a lot of room for deflection or slop. But then again I ran the pants off of it last summer. Heh.
Old 02-11-2018, 01:58 PM
  #180
Might not notice any valve train noise for 5,7 or 10 K miles IMO a “driver” should run thirty to 50 thou with at most a spring change But that’s just me
Most everyone changes setups every few years and never really has or sees any negative issues.
Quick Reply: Junk Pile 4.8 freshen up
