Time to pull the head?
Old Dec 23, 2017 | 10:47 PM
RevGTO's Avatar
Pontiacerator
Default Time to pull the head?
I suffered a rocker arm end cap failure that spit out the needle bearings. Could only account for 1/3 of the bearings even after sweeping the oil pan with a magnet.
https://ls1tech.com/forums/general-l...rain-plug.html
We installed a fresh set of WS6 Store / RPMSpeed rockers but the car continued to have driveability issues. New plugs, wires, O2's and the car seemed to run well except for backfiring at higher TPS/rpms.
Went back into it today and found that the pushrod was slightly bent on the offending rocker and a needle bearing in the pushrod hole. Replaced it, buttoned it back up, test drove it, and the backfire is still there at higher throttle and rpms.
I can't think of anything else to do but pull the head and inspect the lifter(s). I'm open to any other suggestions, but nothing else comes to mind.
Old Dec 24, 2017 | 11:19 AM
RockinWs6's Avatar
Is it backfiring out the intake or exhaust?
Old Dec 24, 2017 | 12:58 PM
When you changed rocker arms, did you check pushrod length?
Old Dec 24, 2017 | 02:00 PM
RevGTO's Avatar
Pontiacerator
Out the exhaust.
No we didn't. The valvetrain is all stock and original.
Old Dec 24, 2017 | 07:37 PM
Originally Posted by RevGTO
Out the exhaust.
Time to check your push rod length. The push rod cups are not on the same plane as your stock rockers, with the new rockers. Im only talking thousandths, but thats all it takes. Id guess you need a slightly shorter pushrod.
Measuring your pushrods properly will tell you what you need.
Old Dec 24, 2017 | 11:57 PM
RevGTO's Avatar
Pontiacerator
Well, if you're right and the geometry is off with the new rockers, and the stock pushrods are too long for these rockers, then potentially all the pushrods could be bent, not just the one on the bad rocker. Another factor in favor of this possibility is that there was no backfiring while driving with the bad rocker. All the driveability issues started after the new rockers; the car ran perfect when the bad one was still in there.
Old Dec 25, 2017 | 07:55 AM
01ssreda4's Avatar
Posts like this make me want to punch the computer screen.
OP, you've likely got something else going on. May be something simple, if you have access to hptuners or similar i would run a scan and see what all the sensors are doing, fuel trims etc to see if you can get a lead on the issue.
Old Dec 25, 2017 | 08:11 AM
big hammer's Avatar
Do a compression test on the hole that had the bad rocker
Old Dec 25, 2017 | 08:52 AM
RockinWs6's Avatar
I'd do um all, backfiring out the exhaust is a sure sign you got a dead hole.
Old Dec 25, 2017 | 09:01 AM
qweedqwag's Avatar
Originally Posted by 01ssreda4
posts like this make me want to punch the computer screen.
Op, you've likely got something else going on. May be something simple, if you have access to hptuners or similar i would run a scan and see what all the sensors are doing, fuel trims etc to see if you can get a lead on the issue.
lmao.
Old Dec 25, 2017 | 09:17 AM
LLLosingit's Avatar
Check the valve springs while you're at it. A weak or broken spring will cause a backfire issue also. Slightly bent valve is also a possibility considering you had a bent pushrod. Along with a compression test here is how I check for a bent/sticky valve.
Pressurize the cylinder, Remover retainer and spring, Use a small pair of vice grips ( I tape up the teeth to protect the valve stem) and clamp them on the tip of the valve firmly and then depressurize the cylinder. The valve should rotate and slide up/down freely.
Old Dec 25, 2017 | 12:31 PM
dreadpirateroberts's Avatar
i read this last night, and thought somebody has their engines mixed up, or thinks OP is running a set of solid lifters or something...
Old Dec 25, 2017 | 03:09 PM
RevGTO's Avatar
Pontiacerator
Yep I have EFILive and did a scan. Fuel trims, everything else is normal. I ran the car in open loop, closed loop, MAF unplugged, and it backfired in all conditions with enough throttle and rpms.
Old Dec 25, 2017 | 03:11 PM
RevGTO's Avatar
Pontiacerator
From PM: [QUOTE=tech@WS6store]The rocker arms are made to be an exact bolt on fit. That's how i did with mine. Unbolted stock rockers, bolted new rockers down, and that is that. i can double check physical alignment and measurements tomorrow. It sounds like you may have lingering effects of the original rocker failure or possible issues from the orig needle bearings causing abnormal wear or issues.
Old Dec 25, 2017 | 07:38 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Spark issues will show up around there also and can cause that, so can fueling. What does actual afr show per bank?
Old Dec 25, 2017 | 07:41 PM
Why would a post like this, make you want to punch your computer screen? Chill bro...stop punching stuff.
Op changes his rockers, and now has backfiring out of the exhaust.
FIRST inclination is that the valves arent closing. Remember that we are working with a non-adjustable valve train. I like the guys at WS6Store, and I buy from them, but maybe something is a little off? I understand variances from hydraulic lifter preload, I really do. Install too long a pushrod in your engine, go out and run it hard and youll likely have the same issues.
And your suggestion is to run a diagnostic, when this is clearly a mechanical issue?
Maybe my SUGGESTION to have the op check his pushrod length is out of line?
Call me crazy, but thats where Id start...
Old Dec 25, 2017 | 07:56 PM
LLLosingit's Avatar
Ummm.......
That and the fact that the rocker arms look to be stock rockers with a trunion upgrade so they should be no different than what he took off.
Old Dec 25, 2017 | 09:18 PM
Ummm.......
Agreed, they should be no different....but is it too much to ask to simply check pushrod length to make sure? Takes all of what, 20 minutes?
Old Dec 25, 2017 | 09:34 PM
It would not hurt but pointing at just that as an issue and ignoring the rest is tunnel vision.
There are many causes of his issue, some of which may still be related to his original problem.
Old Dec 25, 2017 | 10:02 PM
Im not ignoring anything guys. I simply SUGGESTED to START with measuring pushrod length, to ENSURE that the rocker geometry, and cup location is kosher.
I never said thats absolutely the problem, I simply said thats where Id start. You know as well as me that its virtually Impossible to diagnose issues like this over the net. Its probably not the issue...but it could be...its a free easy simple step, and thats where Id start. AND THEN Id look at at other issues once I ruled this out.
