MLS head gasket question...
Old 01-07-2018, 02:28 PM
wannafbody's Avatar
Default MLS head gasket question...
When replacing the factory graphite head gasket on a 2000 TA, is the new MLS head gasket the same thickness. Would the change in gasket require a change in pushrod length?
Old 01-08-2018, 05:03 PM
ss.slp.ls1's Avatar
I don't know what the difference in head gasket thickness is, however I have used MLS gaskets on '98-'02 LS engines with all stock valvetrain components without any issues.
Old 01-08-2018, 05:31 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
If your 853 heads have a notch on the deck of them then we are the only company that has affordable mls gaskets for them. Otherwise use the 12498544 and have no issues. Late 00 cars did get 241 heads also so make sure on casting #.
Make sure your heads do or do not have a notch first!
Old 01-08-2018, 09:13 PM
wannafbody's Avatar
I swapped to ported 243 heads. I was just wondering about the gasket thickness.
Old 01-08-2018, 09:23 PM
12498544 will be fine then
Old 01-08-2018, 09:34 PM
1FastBrick's Avatar
To answer your original question.
The OEM graphite gasket was around .060 compressed
The OEM MLS is around .052
Not enough to make a difference for a stock application. The General used the same pushrods all the way through production.
Old 01-09-2018, 07:10 PM
wannafbody's Avatar
Thanks
Quick Reply: MLS head gasket question...
