Critique my 5.3LS build
I have wanted to learn about the LS family for some time now so I ordered some books and started reading. I feel like I have a pretty good basic knowledge but the more I learn the more I realize I don't know.
Last September I picked up a used 5.3LS off Craigslist for $100 and began this project. A couple of weeks later I traded the old block for a brand new one, here is where I am today:
Gen 3, 2003 New old stock 5.3 LS iron block, deburred.
Gen 3, Stock crank, balanced and polished with Speed Pro main bearings.
Gen 4, Connecting rods with ARP rod bolts and Speed Pro bearings, balanced rotating assembly to 1 gram.
Gen 4, Speed Pro 4.8 LS flat top pistons with Speed Pro rings and floating wrist pins.
Trick Flow camshaft TFS-30602001 and ARP cam sprocket bolts.
(216 duration at .050 Intake, and 220 duration at .050 exhaust and .560 lift)
Trick Flow double row roller adjustable timing chain and billet gears with Trick Flow chain dampener.
Melling standard volume and pressure oil pump.
Trick flow lifters
Reconditioned 862 cylinder heads, with three angle valve job, 2” Manley LS1 SS Intake valves, 1.55” Manley LS1 SS Exhaust valves and Trick Flow double valve springs. I am doing my own porting and polishing.
GM MLS head Gaskets and new TTY Mahle head bolts.
I dont yet know what I will be putting this engine in or even if it will be manual or automatic, but what do you guys think so far?
Next will be to determine my intake etc.
I am working on the head porting as we speak, and have been taking my time and watching as many videos as I can find on it. I am apprehensive about removing the swirl ramp so I may clean it up but still leave some of it in place. 862 heads FYI. based on the cam base circle I have mathematically calculated my pushrods at 7.425" but I have an adjustable push rod to check that after I am done with the heads. I will also measure PTV clearance but I feel like I should be fine there.
I am leaning towards the Fitech Ultimate LS kit for the intake as I don't currently have a wiring harness or computer and I feel like I get a lot for my money with the kit, (intake, TB, injectors, harness, sensors, etc) all things I would need to buy individually.
Do you guys think the Fitech Ultimate kit is a good way to go?
That cam is going to be very mild. It will be perfect for street driving duties. I don't think it's going to have much "rumble" at idle though. You did not list the LSA though and that does play a good part in idle chop. I am in the process of swapping cams right now because the cam I chose is too mild. Keep that in mind. You never hear of people swapping to SMALLER cams.. But you hear about THOUSANDS of people going bigger.
For the money you are going to spend on the FI Tech kit, you could actually SAVE money by using a GM harness and intake manifold, and you would still have enough $$ to buy HP Tuners and do your own tuning. I have no experience with FI Tech but I'm willing to wager that it is not as precise as a GM computer that has been properly tuned can, or ever will, be. I've used GM computers, and GM harnesses on the swaps that I have done. Really straight forward. Intuitive. Everything has already been solved/resolved by some of the best engineers on the planet.
Otherwise you just spend months... years... putting something together... then drive it 50 minutes and something awful happens 9/10 times you are still struggling, pulling it out and doing everything twice, three times. Waiting on machine work, only to find out it was done wrong after you put miles on it and they are not responsible...
When you could have been driving years ago... with a stock engine...
Also whats with the 53 no boost? the whole point of the 53 IMO is the boost ability. Otherwise I'd say get a 427, or 513, or 602, or 735, or 855, or 982, ... +cubic inch engine... not 333 or less. its not even a big number until at least 350 lol.
Trick flow lifters
1. Gen 4 rods/pistons are VERY overkill for a 5.3 that isn't going to see a ton of nitrous or boost. The gen 3 stuff is way way more than adequate.
2. That trick flow cam is fine for a slightly more than stock 5.3. It barely lopes at idle, and anything over 900 RPM it sounds completely stock (I've used SEVERAL of them).
3. The double roller, billet gears, adjustable gear, dampener, lifters, etc are all unnecessary. The stock stuff is more than adequate, especially for such a small cam. You'll likely never see any real world benefit to any of this.
4. The general idea with a budget LS build is to keep it simple. These aren't old small blocks. VERY LITTLE has to be replaced to make decent power with these.
5. You're literally 10 minutes from me.
Do you have around 2,500 in this engine?
Seriously stock rod bolts and re used head bolts have held on tons of engines seeing plenty of hp.....
First, the timing chain is already installed so its a done deal. It might be unnecessary but I don't think it hurts anything so moving on.
I do realize the cam is on the small side, but that's OK I want the engine to have good street manners and I am not trying to build a race engine. I am also not interested in building a boosted engine, not yet anyway. Maybe 5 years down the road after this engine is mounted in a vehicle and has a few thousand miles on it I will get the itch to upgrade, that will be phase 2. Sure I could have built some big cube engine, but this if just a fun project to keep me busy on the weekends while I learn about the LS engine. More cubes = more $$$.
Remember, I don't even know what I am putting this engine into yet and I am in no hurry I already have two perfectly fine vehicles.
I agree that some of this build is overkill but other than spending a little more than necessary it doesn't hurt anything, and if I do go turbo down the road the internals should be OK to 600HP or so. Better too much than too little I say. I have almost exactly $4000 invested at this point.
I am on the fence with the Fitech stuff. I would use the GM computer and harness but I would have to buy new (I don't trust used computers) I will need an intake, TB and injectors also. Where can I get all the stuff Fitech supplies in their kit for less than $1500?
http://fitechefi.com/fitech-uploads/...2010-20-16.pdf
Same goes with computers. I'm fairly baffled at the idea of not trusting a stock one. I also have a VERY poor opinion on FITech stuff, but only when looking at it from a performance aspect.
I don't want to spend more than necessary on this project, but I am happy to spend a few extra bucks to make sure things are reliable and safe to handle whatever I want to do with this engine. Like I said before this is just a project and I have all the time in the world to save up and learn, and I do want to spend wisely.
My head porting and polishing is coming along nicely, I will post some pictures when it is done. After my heads are finished and installed I will be working on the intake system, wiring and computer.
You guys have just about convinced me to skip the Fitech system and go with OEM computer and wiring.
Where is the best place to get a stand alone harness and computer from and what should I expect to pay?
Should I use the truck injectors that I currently have or will they not be big enough?
Do I go with a bigger TB, and what intake manifold should I use if I don't want to use the truck intake?
I am leaning towards using the OEM rocker bodies that I have with a new trunion kit. Should I use bronze bushings or needle rollers, and from who?
Also, where are you located, I'm about 30 miles south of Columbus?
Thanks.
What is the difference between LS7 lifers and LS1 lifters? What makes the LS7 lifters special?
