Idle issue after heads/cam
When I start the car it'll idle for a few minutes until it starts to warm up then it'll start stumbling and then dies. When I start it back up I have to give it a little throttle so it'll stay around 1000. Without moving my foot it starts to bounce around between 1100 and 800 rpms. I realise the tune will help but is there anything I should double check that might cause this before we start working on it with the wideband?
Thanks
You just need a tune. Don't sweat it. It's perfectly normal for it to do that, and idle like crap. If you feel the need to do anything before tuning it, you can open the TB about 1/4 turn at a time and see if that helps. Make sure you reset it each time. It needs more air, plain and simple, due to the reduced airflow at idle, i.e. lack of vacuum. And of course, a tune, which will involve those same adjustments, in addition to fuel and spark.
You want your IAC counts around 30 at a hot idle.
Log your TPS%, IAC counts and desired idle.
The RAF table probably needs more air too but adjusting the T/B blade should get it idling unless your cam is huge.
Yea I adjusted the screw a bit and it's idling much easier. We're going to finish the tune tomorrow. I shall report tomorrow with results.
