Yes, another Push Rod Length ?.
Old Apr 22, 2018 | 01:11 PM
Stampede4ever's Avatar
Default Yes, another Push Rod Length ?.
Ok, here is the deal, I have an LQ4, went from 317 heads to stock 799 heads, new LS7 Lifters, and a Elgine cam. The base circle of the stock cam is 1.551, and the new cam is 1.467.
Will 7.4 length push rods be correct?
Thanks.
Old Apr 22, 2018 | 01:22 PM
Camaroga's Avatar
Buy a pushrod length checker and don't guess.
Old May 4, 2018 | 08:43 PM
Ok, I bought a gauge, checked both sides, one cylinder per side. Had 10 turns out, 0.500" plus 6.800 plus 0.050" pre-load, equals 7.350" stock push rod length, was not expecting that!!!
Does this sound correct?
Stampede.
Old May 4, 2018 | 08:49 PM
Camaroga's Avatar
Are you running aftermarket rocker arms?
Old May 4, 2018 | 08:58 PM
Stock rocker arms, Pac 1218 springs, elgin cam.
Old May 4, 2018 | 09:05 PM
Camaroga's Avatar
I know some roller rockers sit closer to the head, requiring a shorter pushrod. We can rule that out.
Did you check it doing the EO/IC method?
Old May 5, 2018 | 07:56 AM
I will double check again, to make sure. I'm concerned on the numbers, don't make since.
Thanks.
Old May 5, 2018 | 03:51 PM
Well, I tripled checked it, comes out the same every time.
Stampede.
Old May 5, 2018 | 04:07 PM
Camaroga's Avatar
I find it a little strange as well, but 7.350 it is, then. Can't argue with the facts.
Old May 6, 2018 | 08:27 AM
RB04Av's Avatar
That's why we measure, instead of "assuming" or even "guessing".
Old May 6, 2018 | 08:53 AM
98CayenneT/A's Avatar
I would run more than .050" preload on Ls7 lifters
Old May 6, 2018 | 11:22 AM
How much would or should run? I might be a little more then 0.05" but not much.
Don't push rods only come in 0.05" increments?
Stampede.
Old May 6, 2018 | 11:23 AM
Yep, I was going to make reply about that.
Stampede.
Old May 6, 2018 | 11:31 AM
Stampede.
if you measured correctly I would get 7.375.
With Ls7 lifters they seem to have the least amount of valve train noise at around .075" preload
Old May 7, 2018 | 06:03 AM
Are the LS7 lifters the same height of LQ4/9 lifters?
Thanks.
Old May 11, 2018 | 03:54 PM
99'BlackBird's Avatar
That is very helpful since I just purchased some LS7 lifters! Thanks for the tip!
