Best front/ rear seal alignment tool?
CMB:
Mr Gasket:
https://www.holley.com/products/acce...ls/parts/LSRC1
Sac City:
http://www.saccitycorvette.com/AlignItTools.html
Also make sure the seal is lubricated when you install it so it does not burn up.
The GM seals come with a lubricant already on the sealing area.
If the engine has been apart, you need make sure the cover is aligned properly. For that I use the dealer service tools from Kent Moore.
If you follow the instructional videos on our website their is no chance that the tool can cause a leak, even after 30k miles. One mistake that can be made with all these tools you listed, ours included is tightening the oil pan bolts to tight before tightening the cover bolts. Tightening the pan bolts first pulls down on the cover and binds the tool which would misalign the cover. The pan should just be snugged enough so the tool can rotate and is not binding, then torque the cover bolts and then torque the pan bolts.
Another issue would be if you dont leave the white insert in the seal while installing it. That insert keeps the lips on the seal spread so they don't fold in when installing the seal.
Our O-ring design makes for a perfect snug fit no matter the temperature, which can cause expansion/contraction of the tool, crank and covers that will hinder a perfect fit. The O ring design eliminates the problem.
We also offer the tools in a Aluminum Anodized version.
https://saccitycorvette.com/collections/alignit-tools
Thank you
Christian
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
One of the last ones I did developed a bad leak after I did the rear main plate/gasket/rear seal. So I figured I had screwed it up. Since I assumed that I immediately ordered the alignment tools and when they came in I pulled the trans, but the rear seal was perfectly dry. Turns out the oil pan gasket rubber strip separated from the metal at the rear when I slid the rear main plate on and caused the leak. If I had used the alignment tool in the first place I wouldn't have doubted the alignment and I would have likely went for the pan first. So the tool can help in more ways than it's intended use. I did buy the Sac city corvette tools and they are really nice. And even though that rear main and cover didn't leak, it wasn't aligned perfect either, it was off a little. I ended up checking it with the tool and correcting it and it was definitely better. I'll use the tool always from now on. Time is money.
I love tools as much as the next guy, but I agree. Spend your money on some flowers for your wife. At least she will be grateful as you get fucked out of $100
I will say this, I was pretty careful to make sure the last cover I did was straight, it didn't leak and everything was great. But when I checked it with the tool, it wasn't. It wasn't bad either, but it could have been a hair better. And since I'm doing work for customers, $100 to insure excellence is nothing compared to what a comeback would cost, I could lose that customer..
Thank you
Christian
trying to learn a little before i decide to assemble the last half of a short block. i like how easy this video makes it look.......is there anything wrong with using the gm tools? id imagine price could be an issue.....start at 20:30
