Wrist pin problems?
Old May 1, 2018 | 05:37 PM
TahoeNate's Avatar
Default Wrist pin problems?
Was expecting skirt problems this is what i found. Number 6
Old May 1, 2018 | 06:49 PM
A.R. Shale Targa's Avatar
Swallowed some water 💦
Old May 1, 2018 | 07:17 PM
TahoeNate's Avatar
Yikes. It actually was still running pretty strong when i pulled it in the shop . The bottom of the piston had damage from the crank throw.
Old May 3, 2018 | 10:14 PM
00pooterSS's Avatar
I don't see wrist pin problems but I see a bent rod and a lack of oil changes
Old May 4, 2018 | 05:34 PM
TahoeNate's Avatar
Yeah this motor was used and abused with 250k..the wrist pin was notchy i thought that may have had something to do with the rod..disclamer not my motor lol. I work on a lot of dealer auction stuff so i see plenty of mistreated vehicles. Still not sure how number 6 got enough water to cause this much damage
Old May 4, 2018 | 05:55 PM
pdxmotorhead's Avatar
If you get enough water to use up the chamber, or if the water flashes to steam bad stuff can happen.. doesn't take much..
Old May 4, 2018 | 06:10 PM
about one tenth the volume of just one cylinder
valve closes and the piston travels north on a 9.5:1 setup
#weakestlinkgives
Old May 4, 2018 | 08:20 PM
1FastBrick's Avatar
When the crank weight hit's the bottom of the piston from the rod bending, it distorted the pin bore on the piston. That's why it feels "notchy"
Old May 4, 2018 | 09:06 PM
oh so lucky it didn’t rip the pin outta the bottom of the piston. Then all you have is scrap
Old May 4, 2018 | 10:47 PM
TahoeNate's Avatar
I have worked on many a ls over the years but this is the worst damage ive seen personally. But ive never been around modified motors much so i got a kick out of finding it. Im sure guys who race alot see much worse
Old May 16, 2018 | 07:47 PM
TahoeNate's Avatar
id like to add a kiss my dingus too 85 camaro z28 or whatever..buy a real camaro
Old May 16, 2018 | 09:25 PM
They are as much a Camaro as any other Camaro, and handle better than anything built before '82. And with LS power are faster than anything before '82, all other things being equal.
Old May 16, 2018 | 09:56 PM
TahoeNate's Avatar
Owned a 88 loved it lol. Just dont much care for a fellas comments toward me
Old May 16, 2018 | 10:30 PM
I didn't see anything negative to you in this thread. Another thread? Anyway, no problem man. I have nothing against you or anything you said here.
Old May 17, 2018 | 03:19 PM
TahoeNate's Avatar
Different thread friend. Admin locked it no biggie
Old May 17, 2018 | 03:47 PM
Cool. Have a good one!
Old May 17, 2018 | 04:31 PM
TahoeNate's Avatar
Thanks man you as well
