Bent valves?
Old Jun 10, 2018 | 02:40 PM
pdxmotorhead's Avatar
New Cam/Lifters/Rockers,,, Use a high zinc break-in oil,, Its worth it.. Especially new lifters on a new cam, even if its a roller you still gain by getting the right burnish on the cam and lifter whether flat or roller surfaces.. You can see the difference with the naked eye after about 30 minutes of run time.. Dumping a quart in occasionally through the life of the motor is good as well.
All based on road race and sprint cars but I'm a believer.. !
Old Jun 12, 2018 | 04:55 PM
youguessit's Avatar
Deep groove in the bearing
May have spun a bearing? What does it look like to you?
Old Jun 12, 2018 | 08:04 PM
wannafbody's Avatar
I've been told the front bearing always shows a bit of copper.
Old Jun 19, 2018 | 10:57 PM
youguessit's Avatar
I was recommended rotella for break in oil
