Bent valves?
Old May 19, 2018 | 10:23 PM
youguessit's Avatar
Default Bent valves?
I missed third and over revved my engine. I'm going to do a leakdown test tomorrow to test my valves. I checked my pushrods and they were ever so slightly bent(Aftermarket hardened). Anyone know a good shop in the houston area I can drop my heads off at and have the valves replaced in a timely manner if they are indeed bent? (Ls1 engine).
Old May 20, 2018 | 07:58 AM
RB04Av's Avatar
Why not just buy a spring compressor (the giant C-clamp looking kind) and replace em yourself? If the seats are in good shape you can just lap new ones in. All you need is some valve grinding compound... the kind that's not much more abrasive than toothpaste, you don't want the kind that's like gravel.
Old May 20, 2018 | 09:57 AM
bobfig's Avatar
i know on the west side there is LME near beltway 8 and little york. they did some milling for me a few years back and was in and out in a day or so.
1930 Aldine Western Rd
Houston, TX 77038, United States
https://www.latemodelengines.com/
Old May 20, 2018 | 10:18 AM
youguessit's Avatar
Hmn I'll see
Old May 21, 2018 | 02:33 PM
youguessit's Avatar
Couldn't get a compression tester in there to test compression... but was jiggling the rockers and some would move back and forth a fair amount. Maybe collapsed lifters too
Old May 21, 2018 | 03:38 PM
youguessit's Avatar
Any recommendations for high rpm hydraulic lifters? There has to be better lifters than ls7 lifters now a days.
Old May 21, 2018 | 04:53 PM
youguessit's Avatar
I have trick flow 215 heads with tfs-16306-16 valve springs. 238/242 .605/.610 112lsa cam. I would like good lifters that wont fail if I miss a gear. Maybe a new spring lifter combination?
Old May 22, 2018 | 02:03 PM
bobfig's Avatar
in my opinion you should call BTR and see what they think a good lifter would be but i know it is going to be a johnson or a morel lifter. one thing is you are going to need to measure each push rod length because all these have a smaller "sweet spot" of travel to handle the higher rpm. would also look into some of those tapered push rods for better rigidity if you can find them.
my guess is going to ether be
https://www.briantooleyracing.com/jo...st2126lsr.html
or
https://www.briantooleyracing.com/mo...r-lifters.html
Old May 24, 2018 | 01:16 PM
youguessit's Avatar
or
Thanks for the link.
Old May 25, 2018 | 08:45 AM
Bspeck82's Avatar
Talk to Preston at lunati. If anything, he loves to sift out fact from bulls***. Then either buy from him or take the kowledge with you. I just had a lengthy conversation with him yesterday. Great guy.
I'd probably guess they would recommend a link bar style short travel lifter or an OE style short travel lifter, dual springs and steel retainers if it's driven daily. Oh, and measure for pushrods length and feth the thickest rod you can in it. I did not ask Preston but I am to believe a .120 wall should fit. You should find out. That's what I'd roll with when I get my heads done by TEA. Correct spring pressure and lifter preload is the most important thing here. This is why I would recommend consulting a cam vendor before purchase.
Old May 25, 2018 | 11:00 AM
bobfig's Avatar
^^^^ 100% also i think since you are having the heads off and to get looked at maybe have the push rods holes drilled out some so you can use the 3/8" push rods instead of the 5/16"
Old May 27, 2018 | 09:11 AM
8.Lug's Avatar
11/32” pushrods will fit without work. Manton has them in .120 wall.
Old May 27, 2018 | 12:39 PM
HappySalesman's Avatar
IF you want a good hydraulic lifter, Johnson's short travels (I believe the part number is something like ST2126LSR) it takes a fair amount of work to set up correctly (you'll be buying several custom length pushrods) but set up correctly it's one of the best you can get. My valvetrain is quieter now than it was when the car was stock >>
Old Jun 2, 2018 | 11:17 PM
youguessit's Avatar
Thanks all I'm sidelined until I get over this cold. I'll post any pics of noticeable damage to share the carnage. Always interesting to see how things fail.
Old Jun 5, 2018 | 12:02 PM
BlwnLs1GTO's Avatar
Go 11/32/.120" wall Trend or IMO, Manton pushrods at minimum. but before you order them, get your lifters sorted out as well as your head gaskets as you'll be replacing those and measure every single spring with the good COMP pushrod checker and use calipers to measure each valve. Add you desired preload and contact the mentioned vendor(s) above and order them based on your measurements. Tell them how you measured them, too. Very important.
With the way you drive your car, you'll have a good proper sorted (And Quiet since done right) valve train and not have to worry about it for a long time.
Good luck.
Old Jun 9, 2018 | 11:56 PM
youguessit's Avatar
got the passenger side head off and called it a day. So far it looks like it's just bad lifters. No visible touch points between the valve and piston. I was told to put water on the valves and see if it holds or drips into the runners just to double check that they are sealing.
https://m.youtube.com/watch?v=9yLA6arEAWE
Old Jun 10, 2018 | 02:58 AM
youguessit's Avatar
Does that look like normal lifter wear to yall?
Old Jun 10, 2018 | 12:50 PM
youguessit's Avatar
there is mild scoring on the camshaft and I can barely feel super light smooth waves in the lifter roller contact surface. Looks like I need a new cam. I bought mine from g-force motorsports in houston. 238/242 .605/.610 at 112 lsa. I'm going to call and see if they still sell them. I'm short on funds and dont want to pay for a retune. I suspect my lifters have been going flat a while.... also from reading I've not been using good enough oil in the motor. So I'd say failure is from my mistakes.
Old Jun 10, 2018 | 01:04 PM
youguessit's Avatar
I cant remember the head gaskets that are for larger bore engines that are also thinner for more compression. Anyone recall the part # or which vehicle it was for. I think it was for a 6.0 engine. Anyone remember?
Old Jun 10, 2018 | 02:35 PM
wannafbody's Avatar
Use a high zinc oil on a high lift cam with longer than stock duration.
